08 Sierra manifold flip/build thread
Old Oct 15, 2013 | 08:12 PM
black00chev's Avatar
Slowest turbo build ever!
where are you going to run the wastegate? truck looks awesome man.
Old Nov 27, 2013 | 07:17 PM
Iron88's Avatar
I was doing some reading and came across that a lot of people recommend changing the stock oil pump after deleting dod to avoid pumping the pan dry? From what Ive read the stock oil pump is a high volume pump... I was all set to order a standard volume/high pressure pump for the weekend but started thinking about it more is it possible the stock dod pump would be better for a turbo application.... any input would be appreciated... stock? aftermarket high volume? high pressure? Thanks in advance... (im sure im over thinking this...)
Attached Thumbnails 08 Sierra manifold flip/build thread-1424350_750708888276571_1163002328_n.jpg   08 Sierra manifold flip/build thread-578147_750708938276566_728249475_n.jpg
Old Nov 27, 2013 | 07:23 PM
Iron88's Avatar
Hey thanks a lot man! Slowly but surely! I'm planning on putting the wg just before the turbo in the middle of the two pipes coming together and then pipe it into the down pipe from there.
Old Nov 27, 2013 | 07:24 PM
TrickTurbo's Avatar
Truck Sponsor
Pumping a pan dry.
Add more oil to base level if that happens.
Old Nov 27, 2013 | 08:52 PM
Choda's Avatar
looks great. I have not maxed my flex fuel pump and im at 11 psi and 60lb injectors
Old Nov 27, 2013 | 09:04 PM
kelsey_canard's Avatar
Wow, I like this build. Right up my alley. Good work bud.
Old Nov 30, 2013 | 07:44 AM
black79ta's Avatar
Wont stock flex fuel injectors work for normal pump gas? Since the injectors are bigger because of E85. I am figuring out how to turbo my 04 yukon. Looks great!! Keep updates coming!
Old Dec 4, 2013 | 11:32 PM
Low91's Avatar
Nice tablecloth douchebag.
Old Dec 5, 2013 | 12:41 PM
Choda's Avatar
Flex fuel inj will support 6 psi w no prob. Why bother pushing it if u know u want more than 400 wheel?
Old Dec 5, 2013 | 01:29 PM
MarkGMCCrew's Avatar
Registered User
Even my non flex fuel injectors are supporting 6PSI up to 6000RPM just nothing over
And like Choda said the stock Flex pumps are great.
