07 gmc vortecmax procharged 60.l ho
Old May 22, 2017 | 11:14 PM
07 V-MAX's Avatar
Default 07 gmc vortecmax procharged 60.l ho
Alright gents, I had the pro charger installed recently and just had a oil ring wash in cylinder #1 so I'm going in and replacing all pistons and rings....I'm considering a mild cam but this is a daily driver and I don't want to spend too much $$ get'n her back on the road but need some advice on what I should do for pistons & rods as well as a new tune. I'm not gonna be racing her but want a little beef....
Old May 22, 2017 | 11:22 PM
FFDP's Avatar
Factory rods will support 800+ whp no problem so you don't need those, pistons I can't help you there on what you could use. Factory pistons would work fine aswell if you wanted them too.
Old May 23, 2017 | 07:07 AM
07 V-MAX's Avatar
Thx bro for that info, from what I understand with the stock rods and pistons they should be fine even with a little more cam. (i.e. rv)
Old May 23, 2017 | 08:29 AM
madmann26's Avatar
Gap the rings around .028.
Old May 23, 2017 | 09:57 AM
Vortec350ss's Avatar
How much boost were you running? What plugs? What fuel?
A cam will certainly help. Frankly it will actually make it easier on the motor... stock cams with boost have incredibly high cylinder pressure down low. A procharger is better fo that where boost is low, but its still a concern when tuning.
Old May 23, 2017 | 10:36 AM
smokeshow's Avatar
Mod with training wheels
I prefer my cylinder pressure high.
Old May 23, 2017 | 10:57 AM
Don't we all...
Old May 23, 2017 | 03:57 PM
LPCWS6's Avatar
60.L that's one big effin motor!
Old May 23, 2017 | 06:20 PM
07 V-MAX's Avatar
Sorry, I meant to mention Ive got TR6 plugs, bout 8 lbs boost and burnin 93 octane.......
So with that am I right in saying I should be good going with the stock pistons and rods and then a little bigger cam?
Old May 25, 2017 | 03:04 PM
at 8 PSI I would run stock stuff all day long yes.
You need to make sure your tune is in the right ball park and you'll never have an issue.
kc'skustom95
Aug 23, 2017 01:01 PM
Sigurd
Feb 23, 2017 09:50 PM
BayouNola
Feb 21, 2017 11:37 PM
krobinson123
Nov 30, 2016 05:18 PM
GMC SKI
16
May 7, 2002 11:51 AM
