$50 turbo oil feed
Old Apr 19, 2008 | 07:12 PM
sdimer350's Avatar
Default $50 turbo oil feed
hey, thought i would share my oiling system with everyone. rather than spend a couple hundred bucks on fancy braided hoses and an fittings, i used pipe fittings and hydraulic lines. its cheap, flame resistant, and rated to 4500psi. I got a 3/8 pipe tap and ran it into the oil galley hole in the front of the block. it didnt even cut new threads, it just opened it up a bit cuz all i got were tiny little filings. next i threaded in a 3" nipple and put a 90* facing the front of the truck. now i ran 1/4" hyd hose to a remote mount filter boss(Jegs, $25) then from the filter boss to the turbo. another plus was it added a quart to the oil system
filter boss-$25
hyd hose-$15
fittings and tap-$10
Old Apr 19, 2008 | 07:24 PM
Derek @ EDO's Avatar
FormerVendor
Nice job, how is it working?
Old Apr 19, 2008 | 07:27 PM
sdimer350's Avatar
i just ran the truck for a few mins after i swapped in the 5.3 the motor had good oil pressure and the turbo didnt lock up so it must work
Old Apr 19, 2008 | 08:23 PM
vanillagorilla's Avatar
Where do you get that much hydraulic hose for $15. The fittings alone cost more than that.
Old Apr 19, 2008 | 08:42 PM
FormerVendor
Brass fittings aren't expensive and the male ends on the Hyd. hose are cheap as well.
Old Apr 19, 2008 | 08:46 PM
sdimer350's Avatar
i live in south dakota, so i im in the heart of ag/farm
Old Apr 21, 2008 | 09:07 PM
To swage the ends like that around here is like $10 a pop. I had a set of custom ps lines made once and the fittings/labor was a fortune.
So are you offering a service to us city boys need hydraulic lines?
Old Apr 22, 2008 | 12:13 PM
sdimer350's Avatar
sure, send 2 cases of bud light, and i will ship u back one empty box with the hose and fittings
Old Apr 23, 2008 | 08:13 PM
1BadAction's Avatar
Registered abuser
the places around make your lines up for free as long as you buy the parts from them.
Old Apr 23, 2008 | 10:55 PM
dmoss69's Avatar
Banned
Default oil lines <$20
3/8 brake tubing, couple compression fittings, waa laa!
