$24 to lower IAT's on my MP112
Old Aug 30, 2012 | 01:29 PM
  #21
Blacksrt403's Avatar
Harris plate ?
Old Aug 30, 2012 | 01:50 PM
  #22
TX Tahoe Z71's Avatar
Originally Posted by Blacksrt403
Harris plate ?
It was Harris Speed Works... but looks like they are no more https://www.performancetrucks.net/fo...-works-504370/
Old Aug 30, 2012 | 10:50 PM
  #23
Ok gottcha
Old Aug 31, 2012 | 06:48 AM
  #24
Link2603's Avatar
Good idea I like it. I'm with you my truck is not a show truck and I'm looking for ways to lower my iat s right now as well.
Old Aug 31, 2012 | 07:23 PM
  #25
fastnblu's Avatar
Originally Posted by TX Tahoe Z71
I don't disagree, but I'm all about function over form if it's under the hood.
I believe coating the outer foil in Line-x would negate the heat reflective properties of it and actually absorb the heat, which is what you are trying to reduce in the first place
Preston129, got any pics of tube after ceramic/powder coating?
With 2.9 pulley driving normal in south Florida night I was at 40 degrees above ambient. That's with larger hex and water wetter distilled water mix. It was 130 . Humidity has been nuts and heat index was 92 at 9 pm. shitty and no boost period.
Whenever I loook at my IATs on HPT, I'm almost always in the "red", apparently that starts at 104°.
It is a Volant and I do have the Volant "ram-air" tube. Can't say I noticed a SOTP difference or change in MPG, but luckily I only spent $50 on it. The bottom of the filter usually has a decent amount of debris and heavy dirt caked on, so I have to clean it more often.
Those IAT's were "before" numbers. I haven't had a chance to get "after" numbers, but I will update this when I do.
Curious for results.
TX, feels like someone stole my blower was funny, but I can see that in your heat. I know you've tried to cool Radix from threads. I remember the tryin to keep cool Radix thread we both posted alot in. I need to revisit that thread now that I'm boosted.
And now the options of more more & / or keepin it cool get pricey. Meth, NOS, & / or phenolic.
Originally Posted by Ali 556
... If you really want to cool the IAT invest in a meth injection kit, it will DROP the intake to high 60's
Install the tank inside the the cap and the pump below the cap ( they are quite), and run the lines.
AEM Meth kit is 395 $ with free shipping from MVPmotorsports.com.
U do mean inside the cab, right? But why, for meth fillups, cause I can't see a point unless it's for another reason?
$395 for meth is pretty low, as Snow has a low priced kit near that, but options add up fast.
... I've read a number of times that in the real world, meth does more to raise octane than lower IAT's. I run e85 when I want an octane boost.
And I assume your meant put the tank in the cab, which isn't going to happen as it's my DD and it is going to look stock inside and out.
Whatever meth does bettter, whether lowerin IAT's or boostin octane, if it nets more power, I'm thinkin it's the next step to my Radix evolution.
Stock lookin under the hood too?
Old Sep 3, 2012 | 03:26 AM
  #26
Preston129's Avatar
Here's a couple before I installed it:
If the IAT sensor was still in the MAF I would have IR tested the outside of the tube and compared the delta, but since it's moved to the lower TVS manifold it's hard to say what kind of a difference it makes. The tube cools down much quicker once the engine's off, just like a coated set of headers though, I've noticed.
This is my secret weapon for lower IATs though:
Old Sep 4, 2012 | 02:14 PM
  #27
Banned
that crap didnt do anything, thottle response? lol come on man
Old Sep 4, 2012 | 02:46 PM
  #28
03sierraslt's Avatar
Tom- you are in the "red" because you have never adjusted it. Just like the min and max the color can be programmed to turn at certain settings.
Old Sep 5, 2012 | 12:05 PM
  #29
Post up pics. Don't believe you
Old Sep 5, 2012 | 01:58 PM
  #30
Banned
^ if you on E85 like you sig said, your intake temp is no where near high enough to make a difference in HP, E85 doesnt care. is your 95* IAT or 94* after all the tape and bubble wrap, its alcohol, it doesnt care if its 250*
