Eastern VA, MD, DE, WV, PA, ME, VT, MA, CT, NH, NY, NJ, RI
Crank relearn procedure
Old Mar 22, 2008 | 12:21 PM
dan96z71's Avatar
Default Crank relearn procedure
Anybody around with HPtuner or efi live that can run a crank relearn for me?
My trucked popped a p0315 code yesterday and the inspection is due this month. I would rather not go to the dealer and have them void my warranty just yet...
Any help would be appreciated.
Dan
Old Mar 22, 2008 | 04:38 PM
03sierraslt's Avatar
If you lived near me I would do it, but you dont so I am no help... Did you recently change the PCM?
Old Mar 22, 2008 | 04:56 PM
dan96z71's Avatar
I changed it when I installed the turbo back in Dec.
Old Mar 22, 2008 | 05:16 PM
Whippled 496's Avatar
I have never understood the whole crank relearn deal....I have changed my PCM out plenty of times and never had to do a relearn. When is it even needed?
I would help you out too, but you are even further from me than you are 03Sierra
Old Mar 22, 2008 | 07:11 PM
dan96z71's Avatar
Both of my tunes were fine when I first used them, and then after awhile the check engine light came on for it. First time it was just the 93 octane tune from Nelson so I didn't mind taking it into the dealer. This time the light came on after 3 months but with the turbo on there I don't feel like taking it to the dealer if I don't have too.
But honestly, I don't understand the crank relearn either....seems like it would happen as soon as I put the new pcm in there. Maybe I actually have a bad crank sensor???
Old Mar 22, 2008 | 09:10 PM
joshluther's Avatar
You can disable the light and there are a few well know tuners that do it. Any time you change the pcm you should do a relearn it accounts for the differences in the casting and machining in the block... If you don't mind heading down to the casinos I can help you out
Old Mar 26, 2008 | 05:36 PM
dan96z71's Avatar
Hey Josh, when are you available?
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
trxmxzx
Sep 29, 2015 07:42 AM
Velocity1
Sep 22, 2015 01:32 PM
