Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Tc76 365" dyno numbers
Old 09-20-2011, 01:53 PM
11 Second Truck Club
joeyc125's Avatar
I forgot to add, this was the fourth pull and their fans really suck that blow at my intercooler. Run started at 105 iat and ended at 187! I have never seen them this high on the street. Run started at 21 deg advance and was down to a measly 10.5 at the end of the pull.
Old 09-20-2011, 04:43 PM
Slowest turbo build ever!
black00chev's Avatar
Originally Posted by stock48
Those dyno's read way way low. His cam isn't too small I ran mid 9's at 145mph with less.
I stand corrected then!
I guess ill have to get ahold of you when I start looking for a cam when i turbo my truck.
Old 09-20-2011, 06:51 PM
joeyc125's Avatar
I would highly recommend it. As I've said before Jarrett (stock48) advised and supplied me with most of the engine related parts of my truck, and as you can see works pretty well even with not do optimal conditions (too small turbine side and iats pulling 10 deg on the top end.) His truck speaks for itself, mine runs pretty good on the street too. I believe if my iat's weren't pulling so much timing due to the shop having a household size fan, I could have broken 700hp, 10 deg is a lot in forced induction.
Old 09-20-2011, 11:02 PM
Mod with training wheels
smokeshow's Avatar
Damn. I can only run 8° of timing with meth injection and 90° IATs without seeing knock...either the fuel really is horrible here or I am doing something absolutely wrong.
Old 09-20-2011, 11:13 PM
sprayedenali's Avatar
i was at 20* with IATs around 120 (i think) and ALOT of boots on a 50/50 93 and 110 mix FWIW
Old 09-21-2011, 06:50 AM
joeyc125's Avatar
That timing is with e85 and (3) 5lph meth nozzles
Old 09-21-2011, 07:10 AM
Bigschwerm's Avatar
Nice numbers! Congratz....
Old 09-21-2011, 03:38 PM
11 sec. Truck Mod
TIM Z's Avatar
Hot damn shes a runner!
Congrats!!!
Old 11-14-2011, 10:21 AM
slowlsx's Avatar
What size injectors are you currently running and base fuel pressure with 1:1 regulator?
Old 11-14-2011, 10:53 AM
joeyc125's Avatar
I have 74lb injectors with the stock regulator. Runs 58psi key on engine off (base). And goes up to around 61-64 at full boost. Need to go bigger, but I have only heard how sloppy the larger ones spray at low load.
jscherbs
03-24-2017 07:20 PM
Go5.3tt06
25
09-04-2016 10:25 AM
rednekferlife101
09-14-2015 05:27 PM
norris_83
09-09-2015 04:14 PM
11MPG
09-08-2015 04:52 AM
Quick Reply: Tc76 365" dyno numbers
