Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
lq4 + 212/218 + 243s
Old Feb 5, 2015 | 12:22 AM
SWINGRRRR's Avatar
Originally Posted by stock48
If it's on 114 you are definitely giving up some mid range tq but with all that weight an extra 20-30 lbs might not be felt that much anyway. 114 will also idle smoother if that's what you are looking for.
Sorry if this is a hijack, but what if it was on a 112?
Would the peak TQ be a higher number, or just peak at an earlier RPM?
Everything else being equal?
Old Feb 5, 2015 | 12:49 AM
mdwatts11's Avatar
Does it feel a lot stronger with the new setup? It may not be impressive by the numbers, but you know what they say... dynos are a tuning tool.
Old Feb 6, 2015 | 08:56 AM
tim wellington's Avatar
Default cams
2 cams same duration.. lsa 114 vs 112 . 114 more power mid to top .112 lsa more low to mid but with so low duration you probabaly want see much difference
Old Feb 6, 2015 | 10:53 PM
giiventofly's Avatar
It feels awesome, even on the big tires. It pulls noticeably harder, albeit a little higher in the rpms. The whole revving it 800rpms further is new to me but I like it. As I said earlier I'm just dying for it to be warm enough to go to the track for the sake of comparison.
Old Feb 11, 2015 | 07:07 PM
stock48's Avatar
9 Second Truck Club
Just delends on combo and what you are doing. 2 deg won't be a whole lot of difference but 4 deg is. The 112 will make a little better mid range tq and on the smaller cams the tighter lsa's usually make more power thru ought the whole curve. On cams 220 deg + the wider lsa's hold on longer past pk power but give up some mid range.
Old Mar 11, 2015 | 10:40 PM
Fast_six oh's Avatar
So it was dynoed on 35" tall tires?
Old Mar 13, 2015 | 09:40 PM
No, it was stock size tires on the dyno.
I have towed a couple times since getting it tuned and there has been no adverse effects, but I can't say there has been any benefit at all either. For towing I probably should've just re-geared.
Should be able to get to the track soon, hopefully that goes well and makes me feel better about this little project.
Old Mar 13, 2015 | 11:41 PM
With you saying that you didnt see any benefit for towing from the cam swap has me skeptical now..im looking at small cams for my lq9..im wanting more low-mid with a bump in top end..i need some extra grunt when i tow my 87 full size mud truck..ive got 4.10s and 33s too
Old Mar 15, 2015 | 12:09 PM
TXsilverado's Avatar
A small supercharger would be best for towing, but $$$
Old Mar 16, 2015 | 08:42 PM
TVS 1900...lawd those are high
