Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
low numbers on dynojet
Old Jul 23, 2009 | 12:26 AM
RickLowpez's Avatar
Default low numbers on dynojet
well i got a rcsb 2wd h/c(224/581/112,wcc heads) 5.3.truck had dynoed 385 prior on a friend truck in 80 deg temps with stock truck intake(78mm).now i put a tb ss intake manifold(90mm), ls2 throttle body, with tac mod.(is said to only open 85 percent?)the iat was 140 and outside temp was 105 deg.so the truck put down 354/370 a/f at 12.7. so i was trippn on it . dont know if the throttle only opening at 85 per. is killing it that bad or was the heat doing it? i think its like 40 hp down. so im lost on it any help would help
Old Jul 23, 2009 | 12:28 AM
nonnieselman's Avatar
140* IAT is pulling alot of timing and possibly that TB not opening all the way is where your power went.
Humidity plays a big difference also.
Old Jul 23, 2009 | 12:29 AM
RickLowpez's Avatar
was told there was 20 percent humidity
Old Jul 23, 2009 | 12:31 AM
what was the humidity on your first pull and the latest pull with the extra mods..
also did yall have a scanner hooked up to show the TPS?
If you select the wrong PID then its only goin to show 84-85% TPS.
Old Jul 23, 2009 | 12:32 AM
A Low Dime's Avatar
13 Second Truck Club
I cant even read this. Your friend dynoed his truck and made 385 but your truck dynoed 354?
Old Jul 23, 2009 | 12:34 AM
so the truck put down 354/370 a/f at 12.7. so i was trippn on it. dont know if the throttle only opening at 85 per. is killing it that bad or was the heat doing it?
i see now.. i thought it was the same truck...
Different engines are goin to react different with the same setup.. also the timing plays a big part..
Old Jul 23, 2009 | 12:37 AM
RickLowpez's Avatar
yup i did this set up for a buddy , then he sold me the motor and before i put it in i bought the tb ss intake plus whats needed to make it work. now i got the truck running and took it to the same dyno but in the heat. dont know the humidity when my friend dynoed his truck.
Old Jul 23, 2009 | 12:38 AM
same tune?
heat and humidity makes a big difference.
Old Jul 23, 2009 | 12:41 AM
RickLowpez's Avatar
yeah, 2 other guys which were gettn tuned said they were down like 30 hp, but dont know if heat can kill the hp that bad?
Old Jul 23, 2009 | 12:42 AM
RickLowpez's Avatar
not the same tune but same tunner. needed a retune 4 the intake
