Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
joker dyno #'s
Old Mar 22, 2010 | 05:17 PM
  #21
Most Hated's Avatar
Your trap speed is good for a 10 if it 60's hard...
1.58 60ft has been my best, my friend has a similar setup and made a 1.56 60ft and he hit a 10.9
Old Mar 22, 2010 | 05:38 PM
  #22
Blown06's Avatar
8 Second Truck Club
Good numbers man. I've considered spraying mine as well.
Old Mar 22, 2010 | 09:58 PM
  #23
lablackbeast's Avatar
doesn't know what quit means
you will run some nice times ... btw what are you going to do to your fuel system..?? or did you fixed it already...??
Old Mar 23, 2010 | 03:18 AM
  #24
Blown06's Avatar
8 Second Truck Club
Not intending to hi-jack......but
Yea, my sig is way out of date. Still have the little motor and D1sc, but I've upgraded to a 4303 magnafuel pump, fuel cell, return style regulator, etc. I've also upgraded to an 8-rib pulley set up and it makes about 22-23 psi of boost. Best run to date was at the rgv/houston meet, it went 10.46 @ 126.
Looking at the log, its got some still left in it, which I'm working on fixing right now.....
Old Mar 23, 2010 | 03:29 AM
  #25
Most Hated's Avatar
wats the rwhp u have ? timing ? sorry for he q's but nice f-ing times wat pulley u running , and how come ur mph is the same
Old Mar 23, 2010 | 12:42 PM
  #26
i told you you could of done better .... and if i am not mistaken he has the same mph bcause it was running out of fuel (138% duty cycle)
Old Mar 23, 2010 | 03:07 PM
  #27
Mangled03gmc's Avatar
Baltimore Whore
Beautiful...
Old Mar 24, 2010 | 03:01 AM
  #28
Blown06's Avatar
8 Second Truck Club
I stuck it on the dyno and only got to make 1 decent pull. The first pull I only went to 5000 rpm to make sure the tune looked good. It was ok, so I made some changes and pulled it to 6000. At 6000 rpm it made 700 rwhp and the tune up was still waaayyyy shitty 10.5 afr. On the next pull it fried the 2nd and 3rd gear clutch packs in the tranny. Got the tranny freshened up, but never went back to the dyno. Looking at the dyno graph the line was still moving up at a pretty steep angle. I can only think that it would have made over 800 with a good tune up and pulling it to my shift point of 6900 rpm.
Regarding the mph, I attribute it to a couple of things. One, as someone already stated I've got the 60 lb injectors operating around 140% duty cycle. Which is obviously rediculous. I can make changes to the VE table and afr does nothing. I've literally lost control of the injector. Two, my exhaust actually Y's into the stock 2 7/8" or 3" pipe for about 2 feet before it gets to the 4" transition. I have a feeling that my exhaust just can't flow enough air past a certain rpm/boost level. Three, I'm still running the stock procharger 3-core intercooler, which I think is a little restrictive at this power level. I don't think the intercooler is holding me back as much as the exhaust or injectors, but it can't be helping me either.
My current pulley configuration is a big crank pulley and a small blower pulley , and I haven't quite figured out how much timing it actually likes . I'll divulge the full combo when I'm the first D1sc Truck in the 9's w/o NAWZ (with the little motor, btw). Aw'****.....I said it. No turning back now.
Old Mar 24, 2010 | 03:49 PM
  #29
thats possible ... i say go all out on your truck and get some after marker heads. 1 7/8 headers and dual 3 inch exhaust (let that thing bread) also fix the fuel and that will get you there easy .... show what prochargers can do lol
Old Mar 25, 2010 | 04:55 AM
  #30
Most Hated's Avatar
ttt...........
$A_Money$81
Mar 27, 2023 10:25 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
norris_83
Sep 9, 2015 04:14 PM
