Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
hp gains??
Old Aug 1, 2008 | 04:04 PM
ls1klr97's Avatar
Default hp gains??
will i see any hp gains from a stall.......didnt know since it was smaller and lighter if it helped any if at all thanx!!!!
Old Aug 1, 2008 | 07:06 PM
andrew383's Avatar
traveling mod
i think you lose hp on a dyno with a stall
Old Aug 1, 2008 | 07:30 PM
Spoolin's Avatar
GFYS and STFU
Doesn't effect HP at all, just enables the truck to stay in a certain power band longer.
Old Aug 3, 2008 | 02:59 PM
ls1klr97's Avatar
you would think because less weight on the rorating assembly would increase in hp or throttle response!!
Old Aug 3, 2008 | 07:56 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
yes, a little maybe but the largest gain comes from getting right into the power-band of your engine and staying there after each shift.
Old Aug 4, 2008 | 10:48 PM
andrew383's Avatar
traveling mod
i should have explained better
its common to get lower readings on a dyno with a higher stall vs stock stall.
the actual hp doesnt change,just the way its transmitted through the drivetrain
Old Aug 6, 2008 | 10:58 PM
closet red neck's Avatar
Yes, I would agree with this. The stock converter weighs in @ about 54lbs. My 9.5" converter weighs in @ 23lbs empty and when I primed the converter, I reweighed it and came to about 29lbs. However, if I had reprimed my stock converter with fluid, then I might be looking @ 58lbs or almost 60lbs. Cutting the converter weight basically in half would net you some HP gains. I know I felt it in the bott-o-meter........the truck would rpm faster from offline to redline. What were some people saying about rotating mass with wheel and tire combos...........it's like 5x or 7x of the actual weight of an object when you try to rotate it.......It takes a lot more energy to rotate something versus just picking up the object. I tried shaving weight on every little thing just to free up the hp and tq. Just remember, the more you can shave on rotating weight(no matter what it is), the more "free" hp you'll gain.
Just my .02's..........
James
Old Aug 7, 2008 | 01:34 AM
Spoolin's Avatar
GFYS and STFU
Good points! How much of that additional weight on the stock verter is from the actual housing or stator blade compared to how much is from the actual rotating disk or blade?
Old Aug 7, 2008 | 04:42 PM
Are you asking me.....???????
James
Old Aug 7, 2008 | 04:45 PM
I think it's more on the housing than anything.......the billet front hub, smaller internals..........I'm not sure on the inner workings of the converter. I just know that when you loose some of the rotating mass, your truck will get faster on the big end, more power on the dyno and laungh harder out of the hole.
James
