Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Dyno tuned my 6.2 swapped Silverado
Old 05-18-2016, 02:01 AM
WeDgE1's Avatar
Default Dyno tuned my 6.2 swapped Silverado
2006 Chevrolet Silverado ECSB
4WD - 4L60E
Stock converter
3.73 gears
22" wheels/tires
91 Oct
Mod list:
K&N Airaid Intake Tube
Gen IV Truck Intake
LS3 TB
TSP 1-3/4" LTs
Magnaflow 3" HF Cats
Duramax 3.5" Exhaust
LS3 Pistons
BTR Platinum Dual Springs
BTR LS3 NA Stage 1 Cam - 221/228 .609/.571 112+2
Dynojet 224x; ~2116' and ~79*F
Attached Thumbnails Dyno tuned my 6.2 swapped Silverado-truck-dyno-sheet-may162016.jpg
Old 05-18-2016, 09:08 AM
Vortec350ss's Avatar
Solid numbers! I'm surprised how early the HP peaks with that cam... I would have expected it to pull higher than that with those specs.
Is the cam a cam motion or a comp?
Old 05-18-2016, 10:36 AM
madmann26's Avatar
Isn't that motor a rect port? If so, that cam is on the small side. Great numbers nonetheless.
I think those 22's are chewing up a little power.
Old 05-18-2016, 10:39 AM
Small yes, but the large intake port can generally do a good job of carrying power higher.
Being on a 110ICL the 221 duration should peak closer to 6k and not fall off as fast. Thats what I would have guessed anyway...
If its a comp cam with aggressive lobes, like the LSL tooley loves to use, that would explain this to a certain extent. Cam motion lobes are much more rev happy.
01SilveradoJakee
11
05-30-2016 09:17 AM
greenturtle05
04-28-2016 10:44 PM
rondogacing
03-23-2016 10:38 AM
Blwn99x
03-15-2016 09:56 AM
stroker87
03-13-2016 06:12 PM
Quick Reply: Dyno tuned my 6.2 swapped Silverado
