Dyno results
its just the power band of your cam. My 224 227 did the same thing, I swapped to a tv2 cam 232 234 .598 lift and it pulled to 6400. hp different there at 6500 was 60hp. buy peak gain was 30hp.
thats wierd at the track my wideband says 11.2 all the way and the graph to me says it starts lean but then by 3500 its consistent 11 all through run. Am i reading it wrong?
I very well could be wrong, I was assuming the red line was to mark 14.7. If your w/b is reading 11.2 then i would maybe even lean it up just a little bit.
But Ill patiently wait for someone who is a little better with the FI stuff to correct me.
What wideband are you running?
I find it odd that your power starts to fall off at 5300, what are you IAT's like. I imagine they are pretty damn hot and timing is being pulled.
What valve springs are you running? I think the graph looks fine but I would think your HP would keep climbing past 5300, with that cam I think it should peak about 6-6200 (my guess)
