Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Dyno Results
Old Sep 15, 2006 | 01:34 PM
mean05's Avatar
Default Dyno Results
Hi first of kind of new here, but i finally got to dyno my truck monday this wa with high humidity (just got done raining) and an unlocked converter the 384 pull was on a 175 dry shot of nitrous, needless to say that dry shot is gone and has already been replaced with a 150 wet shot using a 1 gallon fuel cell and 110 octane gas, i will have new numbers in a couple of weeks.
Old Sep 15, 2006 | 05:54 PM
Aaron Morant's Avatar
Make sure the runs are performed in the same gear everytime if you plan to compare runs. It looks like you have 1 run in a shorter gear? But like I said, It is only important if you are comparing runs.
Smart switchin to the wet and some 110 for safety and timing (if you can adjust).
What was your A/F?
Are all three runs on the juice?
Old Sep 16, 2006 | 05:02 PM
mean05's Avatar
no the first was on motor then the other 2 were on the shot, i just was curious to see what it would do in 2nd gear on the last run, and there was no a/f they didn't hook up the wideband it was a quick dyno day thing, i am thinking hard about dyno tuning it after i get my heads on, i have a set of patriot heads that i am putting on when i have a weekend free
Old Sep 16, 2006 | 05:27 PM
Sport Side's Avatar
So did you ditch the dry shot due to the dyno results being substantially low?
Old Sep 16, 2006 | 06:37 PM
mean05's Avatar
Yep for now i will be putting a 255 pump in the tank later on after i do the heads and then i will 2 stage it, run the first stage 100 dry shot then the second a 150 wet. I can't see how a 175 dry shot only made 55rwhp so why not make it a 150 wet and make it a true 150rwhp
Old Sep 18, 2006 | 11:42 AM
Always make sure you have some kind of AF monitoring during the dyno run especially on a NOS setup and that goes double for a dry NOS. With NOS you don't get a second chance. When it goes(bad), it usually goes with little to no warning.
Actually there is a slight warning, there is the saying: Cars are usually making their best run, right before they blowup!
Old Sep 18, 2006 | 12:55 PM
thunderwagen's Avatar
Mean 05 are you the guy I talked to at the Frisco meet about a month ago? I have the black VHO with the magnacharger.
Old Sep 19, 2006 | 08:39 AM
mean05's Avatar
Yes that is me, i was out at the meet last night, it was pretty good considering there hasn't been one for about a month, how are you doing?
$A_Money$81
Mar 27, 2023 10:25 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
norris_83
Sep 9, 2015 04:14 PM
