Another 5.3
I think this would be hurting you the most.
I'd slap some milled 243's or some aftermarket heads on there with some 8.1L injectors. Those heads with a cam that big may be choking out the motor; not letting it breath as it needs to. That also may be why your IDC is only at 95%. I would think that a cam that big would be making those injectors cry unless the heads are maxed out, and it's not getting enough air to max out the injectors.
Just my .02
Just my .02
they gave the paper ill see if can get a picture up of it tomorrow.
acutaly im right there with you on that idea going to us a set of 799 same as 243 mill them .40 and use a set of gtp injectors,
Just my .02
Just my .02
Injectors are hurting you, even at 95% they probably aren't efficient for very long.
The heads are hurting you but not to the point that you're only making 311hp. I'd check the tuning aspect. Also, what was the IAT and outside air temp/DA?!
Plenty of guys are making 320+ with smaller cams and the same setup as you i.e. LT's, TBSS intake, efans etc.
I ran a 224/230 .611/.607 111lsa on my old 5.3 truck. It ran great being cam only but the flow of the stock 862's didn't help the big lift of the cam. After I put the P&P'd, valve job, milled 862's on the truck was night/day different and the cam pulled ridiculous on the top end.
The company i went to speed inc they are a very big company they are know for there tuning all over the place but around where i live must people think they do a **** job. I took my chances. They wont give any info about the tune.
maxspeed05V
Sep 23, 2015 10:48 AM
OVOAustin
Sep 15, 2015 08:32 PM
