Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
06 crewcab 6.0 LQ4 dyno numbers
Old Apr 25, 2010 | 11:03 PM
  #21
TXsilverado's Avatar
Originally Posted by GMCtrk
It will be quite interesting to see if you can do it in that big crewcab. I've been doing a lot of thinking about the manifold issue. Richard@WCCH did some testing on the L92 truck intake and LS3 intake both hooked up to a set of L92 heads which we know flow well over 300 CFM stock. The L92 intake only got around 250 CFM through the heads, whereas the LS3 intake managed 290ish CFM. That doesn't tell the story on the low end airflow and velocity that the truck intake can produce, but the top end airflow difference sure is striking. Now, how this relates to your setup....huge flowing heads, but severely limited by the intake manifold. I bet a swap to the NNBS 4.8/5.3 manifold would be a very beneficial swap for you. 007GMC saw 15 rwhp/18 rwtq on his stock cammed LQ4. Food for thought..
coming from someone who has tried the truck, ls6, and a ported fast 90mm all on ported heads...the truck manifold is a performer IMO. atleast in our weight class. dont get caught up in the CFM hype. i have seen lower CFM heads donkey stomp some big CFM heads. it's all in the setup. the L92 heads are always impressive though.
Old Apr 25, 2010 | 11:12 PM
  #22
GMCtrk's Avatar
Good info. Have you been back to the track with the ported fast though? 440 rwhp is extremely impressive through 346 and a truck drivetrain.
Old Apr 25, 2010 | 11:15 PM
  #23
Wheatley's Avatar
Truck Sponsor
it just has 3inch single pipe going to a single in single out 3 inch in/out Borla XR1 sportsman muffler.in front of the Borla it has a dynomax 12 inch bullet.I put that on because without it,it was way to raspy,sounded like hillbillys coming down the road.Sounds good,I like it.
Old Apr 25, 2010 | 11:23 PM
  #24
this aint my thread
wait until you guys see how far charlies power curve holds strong though. perfect for a heavy truck IMO...
Old Apr 26, 2010 | 08:25 AM
  #25
SILVERBIRCH's Avatar
Great numbers Charlie was it dynoed on a 1pc or 2pc driveshaft
Old Apr 26, 2010 | 10:35 AM
  #26
joeyc125's Avatar
11 Second Truck Club
lol, thats how mine was with a catless y-pipe and magnaflow, had to add a bullet in front. helped a ton. You still running the PB level 2 trans? Any troubles with it yet? Thats the trans I am running and am pleasantly surprised how well it's holding up.
Old Apr 26, 2010 | 10:43 AM
  #27
Tootall's Avatar
sounds nice . . . any vids or a dyno graphs ?
Old Apr 26, 2010 | 11:17 AM
  #28
LsxCody's Avatar
pretty good numbers
Old Apr 26, 2010 | 11:54 AM
  #29
TX Tahoe Z71's Avatar
Great numbers Charlie! Glad you finally got it to the dyno. Still trying to find a time to make another pull with mine
Old Apr 26, 2010 | 12:01 PM
  #30
BlackGMC's Avatar
Resident Retard
Wow those are some nice numbers! I bet that thing is a blast to drive! any chance you could post the graph, i would love to see the TQ curve.
