02 LQ9 dyno #2
Since my last dyno I've added Pacesetters/ORY, ported TB, cutout, magnaflow 22" muffler, and Wheatley tune update allowing 28 or 29* timing.
All dynos done in 2nd gear
The green line is my last dyno, stock LQ9, stock intake, stock 4.8L exhaust - stock everything, Wheatley "mid grade" tune - 22* timing
The lowest line of the top 3 is with the cutout open. That resulted in 295 rwhp/ 321 rwtq.
The next pull was cutout open, with the air filter lid open. 305 rwhp / 328 rwtq
Final pull was cutout closed, air filter closed. You can see the engine went lean. 299 rwhp / 324 rwtq
I'm thinking about adding adding a cam and 4.10 gears. Thanks everyone
nice man,a 3rd gear pull would have netted higher hp numbers
with the filter out open it went alittle more lean than I like,but can be expected to throw the A/F off alittle
other than that very nice and smooth curve
those numbers look like mine practically! i have an 03 1500hd that i just dyno tuned this past weekend. I have (OBX longtubes, magnaflow muffler, e-fans, tb coolant bypass, intake, 3 inch body lift, H2 wheel/tire combo)
Other than that, its a stock lq4 6.0
My numbers were 295rwhp 340rwtq. This was on Diablosports superflow dyno (always reads lower than dynojet for some reason)
