Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
e4od
Old Jun 17, 2010 | 05:21 PM
viciousknid's Avatar
Where's the Beef?
Default e4od
91 2wd f150 with a 302 H.O. and e4od. just put the motor in drove about 2 weeks and i shut it off put it into gear and the transmission is not responding at all! im not sure if the wiring harness got hot enough to crystalize the wires or if its a solenoid. any insight where to start? i ran the codes and they were map sensor, vehicle speed sensor, nds, and trans not in park.
Old Jun 18, 2010 | 11:43 AM
chevrolet all the way's Avatar
did you check to make sure the neutral safety switch is plugged in and all connections are good?
Old Jun 18, 2010 | 11:56 AM
Nick™'s Avatar
I'd start with checking the Park/ Neutral safety switch, the VSS and any related harness.
Old Jun 20, 2010 | 11:41 AM
Where's the Beef?
im gonna replace the harness! but would the nuetral safety switch allow it to start but not engauge the tranny? i can shift through all the gears but it seems like the trans is not responding at all
Old Jun 20, 2010 | 06:36 PM
Where's the Beef?
well i didnt have the spare harness but i did inspect it took the nss off and cleaned up everything and still nothin. so i am so lost! can anyone tell me what i will need for a c6 conversion
viciousknid
Jun 26, 2010 12:24 PM
Beatdown Z
Jan 10, 2010 01:02 AM
99CAMMEDSS
Dec 20, 2008 05:45 AM
Hit Man X
Mar 17, 2004 09:33 AM
