Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
305/70 on '02 F150
Old Aug 22, 2005 | 12:12 AM
StrokerAce03's Avatar
Default 305/70 on '02 F150
A buddy of mine has a 2002 F150 4x4 and is getting some tires and rims. We already know that the torsion bars will have to be cranked a little to fit 285/75 16 tires, but he wants to go with 305/70 16's. Does anybody have this combo or know if 305/70's will fit on a stock truck with the torsion bars cranked? He is also planning on getting 16x10 wheels as well.
Old Aug 25, 2005 | 09:58 PM
Anybody at all?
Old Aug 26, 2005 | 05:52 AM
one03sierra's Avatar
Formerly one92rs
Talking
after some research i found this listed on another site.
285/70-17's (33x11.50) will fit easily. In fact, many members have fit 315/70-17's (35x12.50) on 4x4 by using the stock wheels and cranking up the tosion bars.
hope this helps out. those are 33" right. i have an 04 supercrew and i know that they are putting 33's on with a lot of clearance left. i believe that they should work fine. and if at least the tire shop will know for sure.
Old Aug 26, 2005 | 09:14 AM
I appreciate it man. I was thinking that they should fit considering the clearance up front; although the 97-03 do sit lower then the 04+. Its kinda hard to figure out sizes when you don't have the tires or wheels yet, but I think we can make it work.
Old Aug 26, 2005 | 04:39 PM
Formerly one92rs
Talking
i go to tire rack .com and look at the meaqsurments all the time. i think the one that stated that has an older one and a newer one with those tires on it. good luck.
Old Aug 31, 2005 | 10:52 PM
They will fit fine, with a 8in. wide wheel. My brother has them on his 01 F-150 and didn't even need to crank the bars at all. It doesn't rub at all either during normal driving, but if you go off-raod I'm sure it will rub a little then.
bluestang50
Sep 21, 2015 08:36 AM
carid
Jul 24, 2015 05:00 AM
5.3AlmnBlk
Dec 27, 2005 03:00 PM
bodyguard6799
14
Dec 27, 2004 02:46 PM
