TIME SLIP DATABASE
Wheel size combo?
Old Jul 31, 2013 | 09:29 AM
IcyWhite04's Avatar
Registered User
Default Wheel size combo?
I've searched and searched and found a lot of info on disc brake rear setups but I have drums. Looking to run a 15x10 rear if it will clear but not sure if it will fit, what backspace to run etc. what wheel size combo will fit and still be tucked with drum brakes? Right now I'm running factory 20s with 32" tires and they are heavy as hell and killing me. So I'm wanting to run a lightweight street/strip combo with a drag radial. Any info would be great! Thanks
Old Jul 31, 2013 | 10:37 AM
IcyWhite04's Avatar
Registered User
im thinking i might just run some GMC 17s but wondering what size tires people are running? i wonder if 275/40/17 would be to small.. its a 26" tire... going from 32"-26 would be a huge jump and im wondering if that would leave way to much wheel gap
Old Jul 31, 2013 | 11:04 AM
fastjweb's Avatar
26" would be too much wheel gap, but you will get out of the hole faster, my 05 crew cab dropped .5 in the quarter going from my 20's same set up as you, to stock steel 17s on those drag radials. and a 15" rear will fit on your drums, its the disk you have to worry about.
Old Jul 31, 2013 | 11:13 AM
IcyWhite04's Avatar
Registered User
ok cool.. i think im gonna try and sell my 20s get factory 17s and a 275/50/17 tire (28")
Old Aug 1, 2013 | 12:17 AM
Blown06's Avatar
8 Second Truck Club
do a search for bogart
Old Aug 1, 2013 | 12:04 PM
IcyWhite04's Avatar
Registered User
i did look at the bogart threads.. and like i said 99% of the info i found was on disc brake setups and bs for disc brakes. i have drums. im just trying to figure out the correct bs and wheel size.
Old Aug 2, 2013 | 12:21 AM
Blown06's Avatar
8 Second Truck Club
You need a 15x10 with 6.5" back space
Look at my first build thread
Old Aug 2, 2013 | 12:45 AM
dick_landy's Avatar
Mine are 15x10 with a 6.5" back space and 315/60 drag radials.
Old Aug 11, 2013 | 08:20 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
can you run a 15X8 with a 4" backspace on the rear with drums? and be able to run a 275 60 15
Old Aug 11, 2013 | 09:40 PM
dick_landy's Avatar
Yes. Before I had the 15x10's I ran a GM 15x8 truck rally rim with 28x12.5 et street.
Stainless Works
13
Nov 5, 2015 03:31 PM
Lamartian92
Sep 10, 2015 09:27 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
