TIME SLIP DATABASE
what do yall think?
Old Nov 12, 2010 | 09:22 PM
skeet's Avatar
Originally Posted by chevrolade
nope stock l92 heads....and yea i want some 1' 7/8 arh headers into a true dual exhaust.
yall think 29' is too tall?
honest opinion? yes go with a 28x10.5
those heads have dual springs and such right? you need hollow stems and SS valves, REV makes a great valve for those heads.. get it ported, i know a damn good porter if you need any help.
Old Nov 12, 2010 | 09:28 PM
chevrolade's Avatar
yup im running the Patriot Dual Golds....ill be pming soon on that skeet,appreciate it.since im running N/A ide like to bump up the compression
Old Nov 12, 2010 | 09:56 PM
zippy's Avatar
With good tuning that should be an easy mid 12 second ride. I agree on the tire size. I'd go with a 27 or 28 inch tire since you really could get away with a 26 on a good sticky track and a 27/28 range will get you all you need with the suspension working on most tracks. I agree with the Pacesetter part. I'm not quite so harsh on it, but they are a nice header for the money and a very good header for a mild 6.0L or agressive 4.8L/5.3L setup. For an agressive 6.0L or bigger you want that 1 7/8" primary to get things going. You won't even lose any low end power as some claim you will. Some have used the Kooks 4th gen Camaro 1 7/8" as the are almost the same header with a slightly altered outlet. I'm waiting yet to see someone build a 2" header for the 400+ inch trucks. Things are only going to keep getting better from here. You may however run into an issue soon enough with the throttle body. The truck 87mm throttle body tends to flutter and cause issue's much over the 500fwhp range. You can directly replace it with an LS9 throttle body and get rid of that problem. An LS2 will also do the job, but won't open all the way. Make sure you port the throttle body also, even the current one.
Old Nov 12, 2010 | 10:16 PM
chevrolade's Avatar
yea i will be dropping off my truck some time with Allen for a couple of days for some fine tuning.slap my cal tracs/sportsmans on and run a local L...if it dont get the job done im just gonna turbo it.
Old Nov 12, 2010 | 10:22 PM
iamkeniff's Avatar
Originally Posted by custm2500
I don't see 12s at all. Mid 13s seem like a reasonable goal.
right really?! my CCSB on 4:10s with a smaller cam went 13.0@104.2 in 98* weather!!!! i run the same small *** LTs with a bigger muffler!
Old Nov 12, 2010 | 10:25 PM
iamkeniff's Avatar
i say 12.8s or so man hell if not even faster considering the 4:56s those 29" tire is just like me running 4:10s and 28" tires
Old Nov 12, 2010 | 11:14 PM
Beatdown Z's Avatar
Laid Back
Where'd you come up with 13.5? My big heap ran 13.7, lol. I'd be really surprised if you aren't in the 12's.
Old Nov 13, 2010 | 05:33 PM
chevrolade's Avatar
i dont know lol ive never ran my truck ...it moves out good though,i pulled a 02' ws6 at a 20 roll.pulled em quick!!
Old Nov 13, 2010 | 05:39 PM
tarinitup's Avatar
9 Second Truck Club
I wouldn't go off buying new tires without trying the ones I have. I can see it dead hooking with a 29" tire and running some easy 12's.
Old Nov 13, 2010 | 05:41 PM
chevrolade's Avatar
what brand and size u running bro
