TIME SLIP DATABASE
Vince got me to Pinks
Old Nov 19, 2008 | 07:52 PM
67SS509's Avatar
10 Second Truck Club
Transbrakes and pro trees are an *** kicker for sure. Something I did to make mine more stable and quicker to take set at the tree. I installed a line lock on each front wheel right where the flex hose attaches to the steel line (the only way I could see to get around the abs system). I wired them to lock with the transbrake. This way I build up some rpms against the footbrake and creep into the last beam ad then hit the transbrake. It made a big difference with mine. This should allow you to build some boost before you get in the last beam.
Once you lift a head it will continue to get worse with time. If you are not running the 2000 series studs get em and torque to 90lbs. The least you should do is retorque the ones you have.
Old Nov 19, 2008 | 08:35 PM
CurtD's Avatar
Thanks for the info, I do appreciate it
Old Nov 19, 2008 | 09:34 PM
litreddevil's Avatar
Banned
congrats sounds like you'll had fun,we have one at no problem on the 5 of dec.
Old Nov 27, 2008 | 04:21 PM
bud8fan's Avatar
sounded like fun curt....
Old Nov 27, 2008 | 08:32 PM
CurtD's Avatar
Yes it was a hoot...you need to get in on one just for the hell of it.
abey15
Jul 13, 2015 02:20 PM
GMCtrk
Jul 9, 2015 08:26 PM
Derek @ EDO
Sep 23, 2006 09:20 PM
hellbents10
Oct 30, 2005 09:19 PM
