TIME SLIP DATABASE
traction tonight?
Old Nov 12, 2008 | 02:19 PM
BIRCHZ71's Avatar
Default traction tonight?
so tonight im headed to the strip.....trying to decide if i should launch in 4hi or 2wd......on the street if i launch in 2wd i spin for about 60-80 ft.....when i launch in 4hi i usually put into 2wd at the end of 1st and then it lets loose and i go squirrley....i loose tons of power if i run 4hi the whole way though.....any ideas? i'm running 275/65/18 bfg rugged trails....its in between an all terrain and radial.
Old Nov 12, 2008 | 02:25 PM
chevrolet all the way's Avatar
4 lo
i guess take it out of 4 hi when it shifts to second
Old Nov 12, 2008 | 02:27 PM
95 bright teal's Avatar
https://www.performancetrucks.net/fo...uys+launch+4hi
Old Nov 12, 2008 | 02:28 PM
BIRCHZ71's Avatar
4 low......ha! i'm too negative in my bank account to be launching 4 low!
Old Nov 12, 2008 | 02:33 PM
BIRCHZ71's Avatar
thanks 95.....good thread
Old Nov 12, 2008 | 02:49 PM
No problem! did it answer your questions?
Old Nov 12, 2008 | 03:06 PM
BIRCHZ71's Avatar
most definately......im hoping ill just hook considering all the ruber on the track.....i havent ran the truck in about a yr and im running with a few more ponies than last time....ill just have to test and tune with traction tonight
Old Nov 12, 2008 | 03:39 PM
hemidup's Avatar
I run mine in 4hi through the 1/4. Manual transfercase. I have dr's on all four corners. I do a 2wd burnout, then stick it in 4hi for the pass. I check my tire rollout after every track day and rotate them acordingly to keep the rollout to within an 1/8".
Old Nov 12, 2008 | 05:21 PM
Good luck tonight! your truck will hook just fine in 4hi, especially with the tires your running. let us know how it does.
Vortec350ss
Jan 12, 2016 10:36 PM
bearden86
26
Nov 15, 2015 03:58 PM
shootermwc
Oct 8, 2015 01:45 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
