TIME SLIP DATABASE
track times
Old Sep 28, 2005 | 08:36 PM
skindog39's Avatar
Question track times
Any guesses on what the truck will run after the following mods??: 1) Volant Ram Air Intake kit with cold air box 2) High-Performance 2800 stall torque converter from Fuddle Racing 3)the existing exhaust (see signature) and 4) transmission cooler from Tru-Cool
Old Sep 28, 2005 | 10:44 PM
15.30's neighborhood
Old Sep 29, 2005 | 06:40 AM
skindog39's Avatar
any ideas as to how i can get it down in the 14.5 neighborhood?
-Alex
Old Sep 29, 2005 | 07:04 AM
Rhino79's Avatar
9 Second Club
4.10 gears, posi, tuned PCM, I would go with a 3000 stall, with a stall you will need a shift kit, and that should crack you into the high 14's.
Old Sep 29, 2005 | 07:21 AM
skindog39's Avatar
Do I HAVE to get a shift kit? What is it?
Old Sep 29, 2005 | 07:40 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Firms up the shifts makes the transmission last longer increases line pressure doesnt let the lcutches slip as much I could go on and on. No you dont have to have one but it is highly recommended for performance driving. You want the transgo hd-2 kit its the best and most complete. Is it a ec or rc truck? If its ec then its going to take a bit more to get it in the 14s but with your current setup with a tune and traction you would be in the high 14s IMO. Then get gears get rid of the flowmasters cause they are very restrictive compared to the high performance mufflers. Then add a little spray and you should be in the high 13s.
Old Sep 29, 2005 | 07:54 AM
skindog39's Avatar
do you have a link to a site where I can get the transgo shift kit? Thanks! Also, I apologize, but what is rc/ec?
-Alex
Old Sep 29, 2005 | 08:00 AM
Rhino79's Avatar
9 Second Club
http://www.oregonperformancetransmission.com/ Regular cab or extended cab
Old Sep 29, 2005 | 02:19 PM
skindog39's Avatar
thanks...the truck is a regular cab
ARC
57
Feb 21, 2022 10:54 AM
GMCtrk
Jul 17, 2015 06:39 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
coryhussey
Jul 6, 2015 10:23 PM
