TIME SLIP DATABASE
Track talk for Dummies
Old Mar 14, 2006 | 07:22 PM
Last Call's Avatar
TOTM: January 2007
Default Track talk for Dummies
I here everyone talk about temperature, elevation, humidity, barometric pressure, and DA.
I know ideally, a cooler temperature is better for times, to a certain extent based on traction. In higher elevation you run slower obviously.
BUT, more humidity probably makes you run slower?? DA - I have no clue what that means.
Does anyone want to explain the optimum running conditions in terms of the above? I want to make sure I go to the track in good weather conditions.
Old Mar 14, 2006 | 07:36 PM
v8
17,16,15,14,13,12,11 Drvr
DA stands for density altitude
when you put humidity into a DA calculator the elevation never changes, the dew point is the killer. here are the three that you can use, DA calc.,weather,NHRA factors.
http://www.csgnetwork.com/dadtcalc.html
http://www.smokemup.com/auto_math/nh...on_factors.php
http://www.weatherunderground.com/hi...lyHistory.html
Old Mar 14, 2006 | 09:00 PM
FlyingLow's Avatar
PA=Pressure Altitude
DA=Density Altitude
DA is PA corrected for temp and humidity. Colder dryer air gives you more power available. So the colder/dryer it is the better for your engine.
Old Mar 14, 2006 | 09:20 PM
VicRed's Avatar
I think i get it. But lets say a track in Colorado has a DA of 400ft, and a track in Florida also has a DA of 400ft. Even though the physical altitude is different, a given car "Should" run the same times at both tracks? Am I correct here? or way off.
Old Mar 14, 2006 | 10:27 PM
FlyingLow's Avatar
No, DA is not a physical height. The altitude itself is higher in Colorado. Think of DA as how dense the air is at the altitude you are. Plus the temp could be different. DA is a combo of PA/Temp/Humidity. When I'm flying and I want to know the DA I dial in 2992 in my altimeter. Then I compare that to my actual altitude. I then take that number and adjust it for the current temp and humidity.
Originally developed from formulas used by aircraft pilots to calculate lift, this relative performance altitude when calculated for racing includes additional compensation for the effects of humidity on engine performance.
Old Mar 14, 2006 | 11:09 PM
tarinitup's Avatar
9 Second Truck Club
I liked the link to the NHRA conversion table. Accoding to the table my 14.48 would be a 13.98 @ 98.6 mph at my 2881 elevation.
Old Mar 14, 2006 | 11:28 PM
VicRed's Avatar
Thanks Flyinglow.
Old Mar 15, 2006 | 05:32 AM
FlyingLow's Avatar
Thanks Flyinglow.
Cool Over on the SRT forum this is one of the big things the guys in higher elevations complain about. I would brag about my 12.7 and they would fire back that it would only be low 13's out where they are.
Smoke
Old Mar 15, 2006 | 09:01 AM
F8L Z71's Avatar
Its all about DA.
I'm at about 50ft. above sea level yet on a hot summer day the DA can jump to over 3000' so on a really great day in Denver or New Mexico they can actually be "effectively" closer to sea level than I am in regards to oxygen content.
Old Mar 15, 2006 | 03:50 PM
kkd60's Avatar
add also, turbos, nitrous, and supercharged engines are not affected as badly by these factors.
AdaMax
May 16, 2016 11:35 PM
Vortec350ss
Jan 12, 2016 10:36 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Slammed silverado
Sep 28, 2015 06:14 PM
