TIME SLIP DATABASE
There's a new king of the Hill - D1 procharger record 10.45 @ 131.70
Old Sep 30, 2015 | 04:38 PM
  #61
George C....'s Avatar
Formerly ScreamingL
Originally Posted by GMCtrk
They should be listing weights with driver. There's no way a 2wd regular cab weighs 4600 even with a procharger. I know Kurt said his weight was with driver. Neither one seems unrealistic to me.
rcsb here in 2008 with my single turbo setup with stock brakes and 1/4 tank of fuel weighed in at 4640 with street wheels on and i at the time was 175lbs
2012 truck with me 4760 with the twin setup...i was 200lbs in 2012, 14" rotors, full dual 3" exhaust, leather seats, tonneau cover
so a rcsb can be heavy just all depends on options, a LS truck was heavier then a silverado package back then
Old Sep 30, 2015 | 04:41 PM
  #62
GMCtrk's Avatar
Maybe I should have been clear. I was saying that it wouldn't weight 4600 without driver. The early reg cabs were very light, like around 4100-4200 lbs.
Old Sep 30, 2015 | 04:56 PM
  #63
ltr450ryder's Avatar
My 2001 when I bought it in 05 I weighed it without me in it was 4350 without me in it. And it was 100% stock and it was Silverado not a ls package rubber floors crank windows and steel wheels and all it had that was good to me was the 5.3 and posi lol
Old Sep 30, 2015 | 05:18 PM
  #64
Formerly ScreamingL
99-00 had the lightest based on frame design
Silverado package was the lightest
LS has typically was fully loaded
Stsrt of 03 added more weight from Data bus and DBC then the option of LT package....bigger brakes along with drum rears....bigger wheels
Old Sep 30, 2015 | 11:40 PM
  #65
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Originally Posted by dubwise
Nice times!
Maybe I missed it but what was changed from time in sig of 11.4 @ 122 to the new best? That is a significant change in times.
tuning and more boost i was on 10lbs when i ran a 11.4 14lbs now with the 10.4
Originally Posted by BigKID
The weight still doesn't add up. Assuming 'ready to run' is truck only without driver, that's pulling 425lbs out of the truck. What you have listed would be ~250# at most. I'm not trying to be argumentative, just curious as I would love for mine to be that light. My truck scaled 4410 at the track with slicks, exhaust from y back removed and ~1/2 tank of gas. I presume the Procharger setup is a bit lighter than the Kenne Bell but that seem light even for a N/A setup with an aluminum block.
yeah I'm still kinda in shock my truck is so light i was also wondering if the scale at the track was fucked up
well I'm 5-3 150lbs so with me out of the truck full weight with 3/4 tank of gas is 4450
Old Sep 30, 2015 | 11:45 PM
  #66
GMCtrk's Avatar
I've always wondered about the scale to scale accuracy. Some of the weights posted are so deviant I have to question it.
Old Oct 1, 2015 | 12:54 AM
  #67
smokeshow's Avatar
Mod with training wheels
I've found this site to be pretty useful.
Used Chevrolet Silverado 1500 | Pre Owned Used Chevy Silverado 1500 Models at IntelliChoice.com
Can't really verify its accuracy, but it seems to be the most comprehensive site I've come across. Says my current truck's curb weight is 4508. But it says the upscaled models are also the same weight
Old Oct 1, 2015 | 01:26 AM
  #68
Blown06's Avatar
8 Second Truck Club
Before I did any suspension mods on mine it was 4710 ready to race with me in it. If I remember right, I think it was running 11.40's around 120 mph at that time. I was able to shed a little weight when I did the 4/6 drop, 5 lug conversion and other small things. It ultimately weighed 4550 ready to race with me in it when it ran its best. I do remember that a few weeks before it ran 10.46 @ 126, I had it running 10.90's @ 126. I don't have the log anymore, but the it flung the water pump pulley off of it on the 10.46 pass and I remember this being the reason it only trapped 126 again. For the life of me, I can not remember where on the track the belt came off of it. I wanna say it was around 1000' but I really don't remember.
This does have me intrigued though, so I have been grinding numbers through the old calculator. At 4175 lbs, I'm thinking my truck would have run somewhere around 10.teens and 132 mph.
**** man, I want another truck now. lol
Old Oct 1, 2015 | 07:29 AM
  #69
I've got a roll pan fuel cell 20 gallon ditched the rear spare tire tubular trans crossmember rear crossmember were the spare was I cut out I guess all the little things matter
Old Oct 1, 2015 | 08:46 AM
  #70
Formerly ScreamingL
each crossmember cut out is roughly 25lbs from when i weighed them
