Soo close to sixes...
I was looking at that too... my guess was belt slip. Looks like it was slipping at the top of the gear causing it to drop boost, and then when it shifted and RPM dropped it caught back up, and boost jumped quickly. The comp was a split second behind it causing it to run lean for just a tick.
Thats the picture I painted in my head anyway...
It actually just tapped the rev limiter on the 1-2 that pass (and the one before). You will also notice the dip in fuel pressure at the same time. I am still trying to figure out the inconsistent boost since the swap. I previously though the boost was abnormally going up but after more analysis, I get better times and mph when the boost stays up so now I am thinking a boost leak somewhere. I was under the assumption with the new cam/heads the boost should be lower than the previous setup with the same pulley configuration.
Vortec350ss
Jan 12, 2016 10:36 PM
