TIME SLIP DATABASE
slower than normal?
Old Apr 14, 2012 | 02:29 AM
shorty's garage's Avatar
Default slower than normal?
Took my truck to the local 1/8 mile for its first time. 03 rcsb 4.8 60e 3.42 k&n and dual flowmasters full wieght 1/2 tank of 93. Best time was 11.3 @64mph 2.8 60ft. Is this about average or is something wrong with my truck.
Old Apr 15, 2012 | 06:05 PM
blackvmax07's Avatar
where are u located? does seem about a full second slower than wat iv seen
Old Apr 15, 2012 | 06:18 PM
custm2500's Avatar
Ph.D. in HUBRIS
I would say nothing is out of the ordinary. Especialy if the DA wasn't very good. Bad DA can easily take a few tenths from the average.
Old Apr 15, 2012 | 08:03 PM
Lakeland,fl between of Tampa betweens Orlando
Old Apr 15, 2012 | 09:48 PM
custm2500's Avatar
Ph.D. in HUBRIS
I am sure you DA couldn't have been great with humidity so that would explain why you thought you were a bit slower then you could have been.
If you are looking to go fast you have two logical options. Force feed that little guy or swap your self a 6.0. A few guys will mod the 4.8 but unless going FI you are starting from way behind with the 4.8 and a N/A build. Not sure of your plans but you have certainly found a great place to learn how to make your truck fast if that is the goal.
Old Apr 15, 2012 | 11:19 PM
Yea my plans are a low budget competitive dd. Its not my first one, but my first ls powered. I'm pretty close to meeting my plans. I got most the parts just got to find time to put it together. And wait on my stock stuff to wear out.
Old Apr 15, 2012 | 11:30 PM
Vortec350ss's Avatar
That 60' seems way off to me. It should be be that slow at all. They sai every .1 in the 60' is worth .2 in the 1/4 mile, but I don't know how that relates to the 1/8th mile.
Old Apr 16, 2012 | 04:52 AM
Yea something isn't right, there are factors that will make my time different like location and weather but not by that much. Before I started this thread I Googled and found 4.3 owner and ec z71 5.3 owner claming a average of 10.7 1/8 mile. Gave me reason to believe something was wrong. This was somebody's work truck, they drove around handing out foreclosure notices by the paperwork that was there when I got it. Mileage is only 133,xxx. No signs of any serious repairs done to the drivetran. The truck pulls but not till about 4k rpms. Another thing is I ran 4 times that night. That was my best, with 20 psi in rear tires I pulled a 11.7 and 11.6. Aired them back up and ran a 11.4.
Old Apr 16, 2012 | 07:57 AM
Were you having traction issues off the line? That would be the only reason to let air out of the tires.
Old Apr 16, 2012 | 09:39 AM
custm2500's Avatar
Ph.D. in HUBRIS
Air pressure is going to be your friend. As you found out I doubt you will be having any traction issues at street pressure and the extra air is going to help top speed. It is possible something needs tweaked such as a tune up or sensor causing some issues but LS engines like to spin. On top of that you have a tiny little guy under the hood that doesn't make any torque. That is why you feel so much stronger above 4000 rpm. Hell a stock 6.0 loves a 3600 stall.
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Oct 4, 2015 08:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
01silvy
Sep 26, 2015 10:20 PM
TrickTurbo
Sep 23, 2015 08:41 PM
