TIME SLIP DATABASE
slicks with a 4/6 drop?
Old Nov 20, 2007 | 09:10 PM
laynlow77's Avatar
Default slicks with a 4/6 drop?
should i run a 28 or a 26? also they cant stick out of the fenders...
will these work?
https://www.performancetrucks.net/fo...d.php?t=405545
Old Nov 20, 2007 | 09:16 PM
Derek @ EDO's Avatar
FormerVendor
will these work?
3.73's =26
3.73 with boost and nitrous 27/28
4:10's = 27
4:10's with boost or nitrous = 28
IMO
Those might stick out a little bit.
Old Nov 20, 2007 | 09:24 PM
laynlow77's Avatar
so id be a 27/28 then. they can stick out as long as there is some gap for it to launch....
last thing i want to do i crunch my bedsides.
Old Nov 20, 2007 | 09:56 PM
whoopassracer's Avatar
i have a 4/6drop and ran both 26's and 28's full drags slicks and no problems,
Old Nov 20, 2007 | 10:03 PM
FormerVendor
You can do it, BUT for a good MPH a taller tire helps!
I would do a 27/28, not only will it be easier to hook up on but you will increase your MPH.
On the 26" drags i trap like 114 on spray, ive trapped 119 on the 28's I can hook on 26" tires but its hard to do. Ive had better times with a taller tire.
As far as me saying they might stick out that is because of the wheels. I would mount the tires on STOCK aluminum wheels, I have my 28" slicks on them and they fit perfectly!
Old Nov 20, 2007 | 10:20 PM
laynlow77's Avatar
thats what im planning on doing. ill either find a set of 16's, or maybe the new 17's. the more sidewall the better right? 28 on a 16 sounds like the smartest choice.
Old Nov 20, 2007 | 10:50 PM
FormerVendor
I know for a fact a tire with these dimensions
Will fit like a charm on the stock alloys.
Tire Size: 28.00 x 10.00-16
Rim Diameter (in): 16 in.
Sidewall Style: Solid white letters
Tire Construction: Bias-ply
Tire Diameter (in): 28.00 in.
Tread Width (in): 10.00 in.
Section Width (in): 12.10 in.
Which is Hoosier PN# HOO-18153 On Summit
4/6 drop
Old Nov 20, 2007 | 11:05 PM
Cuerva's Avatar
11 Second Truck Club
^^^Hey, that looks just like mine lol. I run the 28's Hoosiers on stock 16's and I have a 4.5/7 drop. The tires tuck when it launches. I would like to run wider wheels but am in the same dilema of rubbing. I won't try that till I get caltracs.
Another thing you can do is run 26's on a 15" rim.
Old Nov 28, 2007 | 01:37 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Derek truck Looks great
Old Dec 1, 2007 | 10:18 PM
bpope's Avatar
Just wondering what the width of the rim is for a stock alloy wheel? I have two stock steel wheels that I was going to put tires on, but I might see if I can find some alloy ones. Plus, I don't know if the steel ones are wide enough.
