TIME SLIP DATABASE
Shouldn't be struggling to cut a decent 60 ft at this power level...
Old Nov 2, 2025 | 12:31 PM
10 Second Club
Default Shouldn't be struggling to cut a decent 60 ft at this power level...
Went to the track this past Friday, decent air finally. Only got one pass sadly, but it didn't go great. Did an adequate burnout, got up on the converter - it leaped out, then spun enough to impact my times.
Current suspension consists of:
Front - 2" Belltech drop spindles, 1/2 coil cut factory springs, Viking double adjustables, front sway bar removed.
Rear - brand new replacement leafs with the overloads removed, Bilstien 5100s with Belltech shock extenders, 2" drop hangers and shackles for 4" overall drop, Belltech rear sway bar, Speed Engineering traction bars.
The truck makes a measly 330 rwhp and 360 rwtq on a 248x dynojet. It weighs 4600 and change with me in it. I run on a 315/50R17 M/T Radial Pro, 17x9.5 wheels. It has a 3800 stall single disc.
On a well-prepped track it has been 1.743 60 ft, this past Friday was a weak 1.876
I have drag springs and stock spindles for the front, I just need to find the time to get them installed and the truck re aligned afterwards. I know the rear suspension isn't ideal, the eventual goal is to to an AFP shock relocation with double adjustables.
I am going to switch to a 15x10 with a 295/65R15 radial and see if it helps band aid the situation. Am I missing anything else? I want to get this thing sorted before I install a new engine and better converter. (LQ9, CNC ported 243s, Circle D triple disc) IMO - it would be pointless to throw more power at it if it can't hook for now. Maybe I'm expecting too much, but I feel like this thing should go A to B no problem in its current state.
TIA
Old Nov 3, 2025 | 09:29 AM
litebulblsc's Avatar
How are your bars setup?
Have you tried different setting on them?
Old Nov 3, 2025 | 04:24 PM
10 Second Club
Haven't tried different settings. They're in the lowest hole currently, and the front snubbers have a minimal amount of airgap. Maybe I need to go up a hole on thebars to soften the hit?
Old Nov 4, 2025 | 10:22 AM
You can try different holes, and mess with different length setting to either preload or more air gap.
Old Nov 4, 2025 | 04:05 PM
10 Second Club
A friend of mine is trying to convince me to buy a set of Smith Racecraft bars. He has them on his truck, makes less HP n/a than mine. Smaller tire, but bias ply. He's spraying 100-150 right out of the gate and it dead hooks. We've run at the same track, so that is a common variable. I'm going to switch to the 295/65R15s and try a few different bar settings as you suggested. See what happens before throwing more parts at it.
Old Nov 4, 2025 | 04:49 PM
I have Caltracs on mine. They started working better, once I was making more power. My best 60ft is 1.35
Old Nov 23, 2025 | 07:17 PM
10 Second Club
Well, the 15" wheel and tire combo seems to be the fix. Warmer weather, still went slightly quicker. More importantly it was consistent and left good both passes. I had the tires at 18psi and got a 1.769 sixty the first pass. Dropped to 16psi and backed that up with a 1.756
No new PB, but feels like a win nonetheless. Installing TBM front brakes on Thanksgiving day, going back to the track on the 30th. Hoping for good air that morning and maybe a 12.7x
Old Dec 20, 2025 | 06:08 AM
10 Second Club
Made some small adjustments to the bars, tires seem to like 15-16 psi. Got a 1.728 and a 1.735 60ft this past Wednesday night. Right now I am happy with how it's doing considering the weight and lack of power.
06sierra5.3
Sep 15, 2016 06:07 PM
foose04
May 28, 2012 10:03 AM
lo&sloSierra
Oct 27, 2008 12:55 PM
VroomVroom
May 15, 2008 10:59 PM
Beastofa327
Jul 28, 2006 08:39 AM
