TIME SLIP DATABASE
rim spin thoughts
Old Mar 31, 2016 | 07:11 AM
tim wellington's Avatar
Default rim spin thoughts
anyone ever had problems with bead breaking on rim ,causing rim to spin and tire not to move off the starting line.I think that what happen to me last week.My 60 ft went 1.52-1.54 to 1.90 -2.15 .log shows rpm and mph match from from previous personal best .log shows a high spike before the gradual pull . i am running the the M/T drag radial 275/60/16 .trap speed also fell from 101-102 to 97.converter slippage in 3rd was 7.59%
Old Mar 31, 2016 | 07:18 AM
TXsilverado's Avatar
Ive had it happen with slicks, but no more than about 3/4 of an inch per pass.
Old Mar 31, 2016 | 07:24 AM
schino's Avatar
i was having it happen. i was losing about 2 psi per pass. I then marked the tires and saw it spinning a few inches. getting a flat going down the track scared me so i screwed them to the wheels and put in tubes. no issues after that. ironically my best 60ft was with them spinning though.
Old Mar 31, 2016 | 07:34 AM
George C....'s Avatar
Formerly ScreamingL
Beadlocks
Rim screws
Glue
Are your options
From expensive to cheap
Old Mar 31, 2016 | 07:56 AM
Atomic's Avatar
I have a gauge for that
Make a mark on the tire and wheel first to see if thats actually your problem, I really doubt it is though.
Old Mar 31, 2016 | 08:36 AM
Formerly ScreamingL
Ive spun tire on rim at 400rwhp...its very possible especially if tire was mounted dry or rim has corrosion on inside
Old trick is to rough off surface prior
Old Mar 31, 2016 | 08:43 AM
Default rim spin
going to put screws in wheels and try again . i was at gallot speedway in benson NC(brand new track) temperature control lanes .other cars were running there best e.t . Seen todd tutterrow go out behind street cars and RUN 3.64 at 216 mph.I know track was right .I feel like if the trans and converter bad my mph and rpm wouldnt match .From previouS run last year .E.T WAS 7.40 flat 1.95 sixty ft 97 mps v/s 6.xx 1.52 sixty ft 102 mph .
Old Mar 31, 2016 | 09:35 AM
Atomic's Avatar
I would still mark the wheel/tire first just to make sure. If you do screws you need to use tubes in the tires.
Old Mar 31, 2016 | 10:01 AM
Slow91z's Avatar
Don't screw radials...use glue
Amazon.com: Permatex 80062 High Tack Gasket Sealant, 4 oz.: Automotive Amazon.com: Permatex 80062 High Tack Gasket Sealant, 4 oz.: Automotive
It works, and people have ripped radials in the most ugly way by screwing them.
Old Mar 31, 2016 | 11:13 AM
Formerly ScreamingL
Ive ran screws in the past on MT radials after i spun the tire very badly...later on ended up passing those radials onto another person and never leaked
