new PB 11.7@119
got 2 11.7 runs but check out the mph!!! so close to my 120 sticker
this is still with crappy 1.9 60 fts and only 12 psi...... god i love corn oil!!
IM #413
first run of the day, i kick my self in the *** on this one cause i ran the tank too low on gas and it cut out for a second on the 1-2 shift other wise i probably would of had my 120 sticker, ohh well live and learn...
best time slip..
IM #413
best time slip..
yeah at like the 100ft mark this truck takes the ---- off! lol . i see some of you guys with 80e's getting 1.7 -1.6 60fts... i dont know how you guys are doing it. i might just need to up my stall to like a 4-4200 stall this 3200 isnt cutting it. i dont know what else to do. even if i stall it off the line i still cant manage anything lower then a 1.900 ... so frustrating.
If you loosen your converter that much, you will loose efficiency on the big end. What rpm you shifting at? Maybe pulley down a bit to bring the boost on quicker, if it's too high at your shift point, drop the rpm's a touch
shifting at 63-6400rpms , i thought about pulleying way down and putting one of those boost bleeders on but i thought that might hurt the top end also with the amount of heat it will make , and i would also need to go 8 rib for sure.
