TIME SLIP DATABASE
new best with 6.0
Old Jul 31, 2008 | 01:00 AM
Default new best with 6.0
went to the track today to try out the 6.0 i swapped last week. heres the results. keep in mind this is at 5800ft at bandimere speedway. It was with the 20's and i spun off the line.
60'.....2.517
1/8.....10.031
mph.....74.31
1000.....12.930
1/4.....15.407
mph.....91.22
Not bad i gained 1.2 seconds from the the 4.8 i had. 15.4 is what a stock lightning runs up here. Can anybody convert my 1/4 to sea level?
Old Jul 31, 2008 | 07:16 AM
Parke10's Avatar
im not sure how to convert but i coulda sworn it was mid 13s for a 6.0 around here and i think out track is at like 400 feet?, but dont take my word for it. one of the gurus will chime in
Old Jul 31, 2008 | 07:20 AM
bluecajun5.3's Avatar
11 Second Truck Club
if you could get your 60' down to 2.00's you would drop 1 second off your time easy.
Old Jul 31, 2008 | 07:23 AM
skeet's Avatar
yep!!! throw a stall in there!!!
Old Jul 31, 2008 | 09:05 AM
TXsilverado's Avatar
agreed....stall and traction.
Old Jul 31, 2008 | 09:09 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Congrats on the improvement!! Running at high altitude is a beetch!
Old Jul 31, 2008 | 10:01 AM
ZO6Ted's Avatar
Do google for NHRA correction factors. Great swap!
Old Jul 31, 2008 | 10:02 AM
Breeze's Avatar
Yep you need to work on getting the truck to hook up which will result in a lower 60' time then you can add more power. Hook up loose the 20s at least on race day and you will have a low 14sec truck if not high 13s
Old Jul 31, 2008 | 10:14 AM
thanks for the help! I have a TB stall not very good though.. I'll see if i can get some stock wheels on it My best 60' was 2.3
Old Jul 31, 2008 | 11:04 AM
stock48's Avatar
9 Second Truck Club
60'.....2.517
1/8.....10.031
mph.....74.31
1000.....12.930
1/4.....15.407
mph.....91.22
Nice times! The correction says you would be low 14's @ sea level, but you will most likely be in the 13's. Everything I have ran both places picked up more at sea level than the correction said. At Bandimere I went 10.85 @14.5psi, and down in Vegas(2300' elv) on a 95* day I went 10.59 with only 12psi.
