TIME SLIP DATABASE
Need lower 60' times
Old May 9, 2010 | 11:40 AM
TXsilverado's Avatar
Originally Posted by trever1t
You have the auto-trac? Damn man, yes, spray out of the hole in 4wd, shift back to 2wd as soon as traction is no longer an issue (if able).
Rule #1) Use every advantage.
You have 4wd, use it!!!!
stock converter and spraying below 2500 rpm can be trouble...just saying lol.
Old May 9, 2010 | 11:54 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
yeah....spray after 3000
Old May 9, 2010 | 12:47 PM
pittman's Avatar
But then its back to that crappy sixty foot. Get a new TC, then spray it out of the hole !!
Edit: don't forget tires with that
Old May 9, 2010 | 06:55 PM
08k1500_3's Avatar
Yeah no spraying for me under 3000. I kinda need to try and save my warranty for a little bit, and GM requires with internal engine and trans repairs that we connect vehicles to check programming,- non supported GM tune= warranty block so I cant take the chance right now of blowing it up. Next on my list is cam/lifters/pushrods/rockers, Converter and some decent tires
Old May 9, 2010 | 07:20 PM
fastnblu's Avatar
" Yeah no spraying for me under 3000. I kinda need to try and save my warranty for a little bit, and GM requires with internal engine and trans repairs that we connect vehicles to check programming,- non supported GM tune= warranty block so I cant take the chance right now of blowing it up. Next on my list is cam/lifters/pushrods/rockers, converter and some decent tires."
Good thing you're not doin anything that could add power.
FWIW, on my 1st few tries back at track in a few yrs., & yes I know I'm 2wd, I ran 15 flat. I know I spin more than 2', & I run a 2.27-2.28 60'. You've got a second on me w/. a better gear too.
Old May 10, 2010 | 09:51 PM
silver-mod-o's Avatar
Hunt&Fisherator
I'd do a converter first before any other mod... Call Circle-D and get his 278mm 3200 stall and you'll be able to spray it out of the hole and in 4wd you'd be suprised how quickly your 60fts drop... You should be able to get deep in the low 1.9s I'd say with some weight reduction.
Zizzle
Oct 19, 2017 08:44 PM
1979rs/z28
Sep 23, 2015 08:39 AM
mrhino
Aug 7, 2015 10:01 AM
signguy62
Jul 27, 2015 03:42 PM
Ammadien
Jul 22, 2015 08:50 PM
