TIME SLIP DATABASE
might go to the track this week, need input
Old Jul 24, 2011 | 07:21 AM
Gadgetized's Avatar
Default might go to the track this week, need input
I might be going Wednesday night if it is a good night out to run. I went a couple weeks ago, and hadn't done much WOT tuning at all. I ran a 13.4 @ 101 with a 2.0 60'. I took out some fuel and added 2 degrees of timing, and ran 13.0 @ 105 with a 1.96 60'. I didn't intend to leave the line hard, I wanted to work on the tune up top, so that is why my 60' is so bad. I barely warmed the tires up, and left the line real soft. I added another 2 degrees of timing, and someone put oil down the whole track, so I was done for the evening. My AFR is right around 11.4 now, and have added a few more degrees (I'm around 26 now) without any KR. I also have since raised my shift points up, as my truck should make power up to 7k (I'm shifting out of 1st @ 6800). Last time I went I had 3/4 tank, my tonneau was on, and about 40 lbs of stuff in the cab. I am running 275/55/20 tires at stock pressure. In the near future I plan on getting Caltracs's. Does anyone have any suggestions for the next time out?
Old Jul 27, 2011 | 01:38 PM
fortplainman's Avatar
im gona embarrass you tonight with a lifted 4x4
Old Jul 27, 2011 | 01:49 PM
TXsilverado's Avatar
Old Jul 27, 2011 | 02:03 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You're running 26* timing at WOT? Holy *****!
Old Jul 27, 2011 | 06:49 PM
swift700's Avatar
LOL, yeah that's a lot.
Old Jul 27, 2011 | 10:25 PM
eh track was closed tonight, will have to hold off my embarrassment for a couple weeks lol
Old Jul 28, 2011 | 10:42 PM
Gadgetized's Avatar
Yeah, I am running a lot of meth, and it is pulling hard. I know 26 is pushing it, but it is running so darn good. I really want to get it on a dyno to see if it is helping with that much advancement.
Fortplainman, I'm still on for the 10th, it should be a good time. I can't wait to get a half way decent run out of this thing. It is sort of funny I haven't gotten into the 12's yet, and this truck should be capable of 11's I would think. I need to get it to hook, it breaks them loose on the street at 40.
Old Jul 28, 2011 | 10:53 PM
Something seems amiss with your setup. Do you datalog your runs? Do you use HPT or EFI?
Old Jul 29, 2011 | 08:48 AM
Gadgetized's Avatar
I think something is off too. I just can't figure it out. I am using EFI Live. I don't actually own it, a friend has let me use his. I do plan on buying it in the very near future.
My truck weighed about 5000 when I went down the track, and I got it to 4820 after removing the tonneau. It also has 275/55/20 on all 4 corners, and I haven't changed the pressure in them yet. I barely warmed the tires up (i don't like getting street tires too hot, just mainly clean them off), and was only able to get a 1.96 60' time. I'm gonna find out next time I go to the track if the tonneau hurt or helped me. I have also since bumped my shift points up. It was shifting at 6000, and now I am shifting out of first at 6800. I would think this combo should pull all the way up to 7000. I do plan on dropping the air pressure in my rears, and maybe increasing it in the fronts. Any advice would be helpful.
Old Jul 29, 2011 | 05:12 PM
If you bring the truck to me, I'll help you get it running right.
You really should get your own tuning software. Just datalogging your runs & emailing the files to a good tuner will help you(as a start), until you are tuning it yourself.
Is your truck 2WD or 4WD? I'm assuming you have a 6.0 in there.
