TIME SLIP DATABASE
Made some Low boost run's today.
Old Apr 24, 2008 | 12:29 AM
stock48's Avatar
9 Second Truck Club
Default Made some Low boost run's today.
Went to the street leagal test night at Bandimere for a few low boost passes. Ran the truck at full weight bed liner,and tailgate on, full tank, 245/17 street tires. Probably right at 5000lbs, Ran the .68 AR EX housing. Da was 8800' Track was WAY better than the two other times I snuck up on the 60', the little 245's were doing pretty good. For some reason my truck didn't want to MPH on a few passes. The first pass was at 8PSI, no meth, and soft launch. All the othere were 10PSI with meth. Remember 10PSI up hear is like 7PSI down there with more heat, and lag. Bandimere sitts at 5860' above sealevel. Im confident I could have run high 10's with the ET street's even at only 10PSI, or hit high 10's on the street tires if I up the boost to 12PSI or add alittle timing. Made 8 runs all right on the limit of being kicked out, had a blast.
8.5 psi no meth.
10PSI with meth
Old Apr 24, 2008 | 12:47 AM
kbracing96's Avatar
Damn J, you got somthing right on that setup,
Old Apr 24, 2008 | 01:20 AM
stock48's Avatar
9 Second Truck Club
Thank's Kyle! I just wish I could make a few more high boost runs without caging. I know there is alot more left in it, even up hear. Last time out on the shitty track when I went 10.85 with the ET streets the best I could do on the 245's was a 11.8. That track today would have hooked a 4000+ RPM 10PSI launch with the ET's, and the head wind was alot less too.
Old Apr 24, 2008 | 01:45 AM
53RUSSELL's Avatar
wow that thing fast.
Old Apr 24, 2008 | 05:29 AM
Wilde Racing's Avatar
How do I change this text
WOW pretty impresive. so how much kpa of boost?
Old Apr 24, 2008 | 05:47 AM
stock48's Avatar
9 Second Truck Club
Thank's! About 150KPA at 10 PSI.
Old Apr 25, 2008 | 03:18 PM
WJ MARK's Avatar
I Noticed this dmax exhaust is still sitting here, I thought you were gonna stop by and pick it up on your way back???
Old Apr 25, 2008 | 03:59 PM
stock48's Avatar
9 Second Truck Club
It was late, and I had to eat. I will try to get up there next week, or maybe this weekend, if I go to denver. I also can't remember how to get to your shop.
Old Apr 25, 2008 | 05:26 PM
WJ MARK's Avatar
WHATS WRONG WITH THE $12.00 BURGERS AT THE TRACK??
Old Apr 25, 2008 | 05:32 PM
stock48's Avatar
9 Second Truck Club
They had allready shut down, and I wanted chapotle!
stealthperf
34
Feb 14, 2016 11:35 AM
thunder550
Oct 8, 2015 04:53 PM
Gadgetized
Jul 18, 2015 02:15 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
