TIME SLIP DATABASE
to lock or not lock converter
Old Apr 11, 2012 | 02:39 AM
RickLowpez's Avatar
Default to lock or not lock converter
im trying to figure out if its better to lock the(95mph) converter at track?i had it locked on my 06 rc with a 6.0 it ran quicker , but now ive got the 08 rc 5.3 with full bolt ons heads, cam. has anyone tried it either or? thanks
Old Apr 11, 2012 | 02:47 AM
smokeshow's Avatar
Mod with training wheels
Depends on power output and whether or not you have a multi disc. And obviously, whether or not it slips...
Old Apr 11, 2012 | 03:36 AM
RickLowpez's Avatar
the converter is a multi disc pi 3600
Old Apr 11, 2012 | 04:21 AM
smokeshow's Avatar
As long as it doesn't slip, you're good to lock it up. Mine slips so I don't...still working on that one.
Old Apr 11, 2012 | 09:00 AM
pittman's Avatar
I lose a little hp on lockup. It isn't much but dropped about 3-5 hp.
Old Apr 11, 2012 | 09:13 AM
TXsilverado's Avatar
get on the track and try it both ways. it's the only way you will find out. mine seemed to run the same times with it locked and unlocked.
Old Apr 11, 2012 | 07:29 PM
RoadKill03's Avatar
lock the biatch up
Old Apr 12, 2012 | 01:07 AM
RickLowpez's Avatar
Originally Posted by RoadKill03
lock the biatch up
thqats what i was thkn thanks
Old Apr 18, 2012 | 05:06 PM
ayousef's Avatar
if its a high stall converter then you're probably loosing quite a bit by keeping it unlocked, but a small stall say like a stock stall converter and you probably wont feel/see a difference, with you're 3600 and depending on your power output you could gain quite some power by locking
Old Apr 18, 2012 | 08:14 PM
foose04's Avatar
If your not turbo, I say go ahead and try it. For the turbo guys, expect 2-3psi increase, maybe more from load change. That said make sure you have the fuel and tune ready for it.
I locked mine a few times when I was trapping 122-123. With it locked, it went 125 but the ET's stayed the same. I didn't like the big boost change so I leave it alone.
Idryfly5
Sep 2, 2022 08:55 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
