TIME SLIP DATABASE
A little drag racing tip for you STS guys with EFILive or HPT
Old Sep 30, 2006 | 03:48 PM
kbracing96's Avatar
Default A little drag racing tip for you STS guys with EFILive or HPT
Ok, so we all know how the STS builds boost faster when all the exhaust pipes and turbo housing are good and hot. So I decided to try something last night. A couple of minutes before it was my turn to go in the staging lanes, I used the bidirectional controls to command 11:1 fuel and 6* of timing while just sitting there (swich it back before I made a ran). It runs really rough , but it's dumping some REALLY hot exhaust gases in to the pipes heating them up quickly. Help me launch at 3300rpm (on a 22-2400 rpm DACCO remain TB stall) and 8 psi of boost, which netted me a 1.88 60' time
Old Sep 30, 2006 | 04:08 PM
TURBO8's Avatar
Very nice, I sit in the staging lanes, building boost with the two step. I build about 5 psi and let off. I do this twice and then run. The people around me look at me like I am crazy. My blow off sounds like a drowning rooster. LOL
Old Sep 30, 2006 | 04:46 PM
nonnieselman's Avatar
That sound pretty cool!
How did you figure out about the AFR and *6 of timing?
i can never keep this right but is 11:1 rich or lean?
Since 14.7:1 is the ideal AFR, shouldnt 11:1 be lean? that would be 11parts of air to 1 part of fuel? less air?
Old Sep 30, 2006 | 05:10 PM
kbracing96's Avatar
I just took a stab at the numbers, but It seems to work. 11:1 is rich. Less air= more fuel= rich
Old Sep 30, 2006 | 05:13 PM
kbracing96's Avatar
Ya, I know what you mean, I do one dry hop in 4 wheel drive trying to boost at much as I can and build some heat in the pipes. Some people ask me why I try to do a burnout when my truck won't spin the tires
Old Sep 30, 2006 | 05:41 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Next time out try -5* and maybe 10.5:1 or even 10:1
The old covair set used to wire up switches to "bog" the timing to heat everything up and build boost. A lot of 'em even launched that way and then threw the switch off as soon as they were spooled up. I've been trying to figure out a one switch deal with the truck, but can only come up with mangling a valet mode tune.
Old Oct 1, 2006 | 11:09 PM
J dubb's Avatar
1.88 60ft is that good for your truck? I have been looking at switching over to turbo set up, but that seems a little bit weak on the 60ft.?We cut low 1.83's, and a best of 1.79 with a p1sc making 4 psi out of the gate? I'm not trying to be a dick, just asking.
Old Oct 1, 2006 | 11:18 PM
kbracing96's Avatar
What kind of vehicle???
I have a 5500lbs truck and only a 293ci motor, I would say it pretty good. That's a lot of weight to get rollin with a little *** motor.
Old Oct 1, 2006 | 11:28 PM
J dubb's Avatar
escalade on 24's with a 6.0l. I'm not saying it's bad. I just haven't seen any other post. How does this compare to your other 60ft. times?
Old Oct 1, 2006 | 11:37 PM
kbracing96's Avatar
BIG difference on low end torque of a 6l and a 4.8 (71ci). The 4.8 has a LOT shorter stroke. Best 60's before where in the 2.0+ range with leaving around 4 psi of boost. Ran a new best Friday night with a 13.47@100.7
