I want to go faster
Im not too sure if this is right but my fastest time is a 14.50 at the track. With the mods in my sig does that look pretty accurate? also with like a 2.2 60ft. also i had my stock wheels on when i ran.
Originally Posted by sig
05 chevy rcsb 2wd. 5.3
pc long tubes
k&n cold air
elect fans
throttle body spacer
nelson tune
detroit trutrac w/4.10's
2/4 drop on 22in kuhmos
pc long tubes
k&n cold air
elect fans
nelson tune
that is kind of what i was thinking just by researching everyone elses time on here..I dont really get it. Im not really spinning off the line but I cant just punch it either or it will lose traction. maybe i need to properly adjust air pressure and try to launch a little harder.
What are the track conditions, and where is it?
I think a 14.5 is pretty good for his mods. If you had some drag radials and got your 60' down to a 2.0X, you'd probably see a low 14.
BTW- Nice lookin' truck!
you know I cant really recall the track conditions and of course I lost my timeslip since then. I live in south florida and this was at Moroso Motorsports. Its kind of aggrivating cause I feel like i should be a little faster, but I should deff try to get my 60ft down a little, with help of some different tires i suppose. btw thanks
South Florida= heat and humidity. Probably not helping.
The next time you go, just use the DA calculator in the thread below and it'll give you your corrected time and speed.
https://www.performancetrucks.net/fo...d.php?t=426679
I feel your pain though, last time I went I only ran a 15.0 but thought I'd do better. Poor track conditions and no traction killed me.
Good luck~!
Good luck~!
Good luck~!
Good luck~!
not to jack your thread, but i'm in the same boat as you. i have very similar mods, but with the addition of a 3,000 RPM stall and i'm 4x4. i launch in 4wd, but can only get a 2.1 60' and my best time is a 14.64. i feel i should be in the low 14s, but i'm not even close. i feel my tune is off...
