TIME SLIP DATABASE
How to pick up MPH??????
Old Mar 3, 2007 | 08:53 AM
Default How to pick up MPH??????
hey guys im running 8.3's @ 83mph right now. the truck is almost stock aside from my custom turbo set-up @ 10psi
im looking for ways to get my trap up to 86 or 87mph.......
@ 8psi my trap was only 80mph. do you think by upping the boost to 12psi i could get another 2 or 3mph out of the truck
also what a shorter 3000stall torque converter?
Shorter tire?
someway to move the power curve up in the rpms a little? (e-fans?)
any help would be appreciated.... im happy with taking down stock Fbodies and stuff like that but i would like to start getting into faster car territory which is why i need a better trap..
thanks
Old Mar 3, 2007 | 09:23 AM
krambo's Avatar
Shorter tire and lock your converter earlier.
Old Mar 3, 2007 | 11:13 AM
onebadrubi's Avatar
Do you lock your converter in the 1/4? I thought you werent suppose to?
Old Mar 3, 2007 | 01:31 PM
also i have a 31" tire. and heavy *** wheels and tires. going to a shorter tire and a lighter wheel/tire combo would that help with mph @ all?
Old Mar 4, 2007 | 02:42 AM
99Silverado5.3's Avatar
Going lighter will help.
Old Mar 4, 2007 | 10:35 AM
krambo's Avatar
I do. I experimented with various lock-up points and for my application, just after the 2-3 shift is ideal for a good balance between MPH and ET (for me).
Old Mar 4, 2007 | 10:37 AM
nightrunner's Avatar
Mr. Obvious
add about a 75-100 shot that would help
Old Mar 4, 2007 | 11:00 AM
speedy02's Avatar
A lighter wheel and tire combo will help some. What gears are you running? Most turbo cars like tall gears.
Old Mar 4, 2007 | 11:01 AM
3.42's on stock converter.
Old Mar 4, 2007 | 11:23 AM
litreddevil's Avatar
Banned
it all depends on the hp curve and where you are shifting and where u r crossing the finish line if shorter tires will help
