TIME SLIP DATABASE
How fast are cam only 6.0 rcsb?
Old Jul 6, 2017 | 01:49 PM
53bowtie's Avatar
Originally Posted by 03chevytruck
when my 2003 truck was bone stock with 342s, borla mufflers and diablo sport programmer, it ran a 14.5 the very first pass i ever made on a track in my life. With like a 2.5 sec 60' on street tires.
I had a ecsb that went 13.88 with a bone stock 5.3. I swapped to a bone stock 5.7 ls1 and went 13.27. 6/10 gain from cubes alone. the LS1 and 6.0 have similar HP characteristics with the 6.0 having a bump more torque. take it for what it's worth. I would expect 50-60 hp out of the motor swap.
Man I don't know how on earth yall are getting such good times with stock 5.3's unless they have full bolt-ons and aren't really "bone stock". I was around the 15.4ish range with my stock 5.3 down to the factory exhaust manifolds and tune. Swapped in the 6.0 and street tune and ran a 14.2ish with everything else being equal. Dropped over a second with cubes and a tune.....
Old Jul 6, 2017 | 02:01 PM
TXsilverado's Avatar
bone stock 5.3 to me means that the motor has never been cracked open. headers, intake, throttle bodies, tunes, gears, converter, exhaust doesn't mean it's not a stock 5.3. it's a bone stock 5.3 with **** bolted around it.
Old Jul 6, 2017 | 04:54 PM
03chevytruck's Avatar
As stated, the only mods i had were dual exhaust and a diablo sport programmer. Oh and the overload leaf spring removed.
Old Jul 6, 2017 | 05:11 PM
madmann26's Avatar
It's in the tune.
There is a ton of **** that needs tweaking in the tune.
Your spark curve plays into as well. How fast you get into PE mode, burst knock, etc etc.
That's not even touching the ve or maf tables. A proper tune takes a few hours.
Throw away the intune, please.
Old Jul 6, 2017 | 05:50 PM
Originally Posted by madmann26
It's in the tune.
After i put cam, stall, intake, etc i went to Thunder Racing(now EPS) for a dyno tune. This was in 2005... Plus it ran damn good for a handheld programmer, although that is the first and last one i have owned. Custom tuning is the only thing i will ever get.
Old Jul 6, 2017 | 05:55 PM
This was in 2005..... After i put cam, stall, intake, etc i went to Thunder Racing(now EPS) for a dyno tune.
Geoff at eps is one of the good tuners from what I understand. never used him myself so I can't speak first hand.
Old Jul 6, 2017 | 05:59 PM
Geoff was the only person i ever used until i recently went with Atomic for my last tune. Goeff also specs all my cams. Ionly had Atomic do a segment swap for the 4l80e but will be using him to review my logs and have his supports for when i go turbo!
Old Jul 6, 2017 | 09:33 PM
ZO6Ted's Avatar
Bone stock can mean stock long block with all bolt ons and tune? Its all in the details I guess. Like still a virgin but she only gives head and **** really well Ok back to regular programming....
Old Jul 6, 2017 | 11:50 PM
The 5.3 is still stock. Its like a boob job, lip injections, *** implants and **** bleaching on that virgin. All those bolt ons dont change the fact that her bottom end has never been split open.
Old Jul 7, 2017 | 10:26 AM
ZO6Ted's Avatar
Sure loved the sbc for years and years but LS is the king now. If I put together another ride it will be a stock block ls.
