how bad are my times
#54
Okay thank you. I'm in the middle of rebuilding it now. Once done I can put it on are tranny dyno. Only thing I'm looking into still is the stall due not knowing if I.wanna spend a ton or not. Worried about the tranny giving out again. If that happens I'm just going 4l80e.
#58
You need the converter. That will get you solid 12s. Maybe 12.5. Then big gains are from more boost, or a little nitrous if she doesn't like leaving the line still.
There are many other little tweeks what will help but most everything else is only going to be a tenth or two.
#59
You need a cam, converter, headers, sticky tires, more boost, meth and allot of tuning. I am not sure if the PISC is going to get you where you want, you are asking quite a bit if you are shooting for low 11's. At that point you are going to want a 80E.
#60
I do plan on the heads, cam, meth. I wanna see how low the p1 can get me before going turbo. I do plan on the 80e when I get back to Fl. Just rebuild the 60e for bow since it was under 400 and in school.
