TIME SLIP DATABASE
hooking up
Old Aug 24, 2009 | 03:44 PM
black04silverado's Avatar
Default hooking up
i am having trouble hooking at the track. b4 my stall i could spray out of the hole and dead hook ,and i now a have a edge 3600 and i spin like crazy
any tips or tricks i can use to help me hook up
my mods in sig and my tires are hoosier 28/10/16 slicks
Old Aug 24, 2009 | 04:05 PM
Atomic's Avatar
I have a gauge for that
dont spray out of the hole?
Old Aug 24, 2009 | 04:17 PM
then i cant run my best time i run slower than i did b4 the stall and im trying to go faster not slower
Old Aug 24, 2009 | 04:24 PM
Atomic's Avatar
Whats your 60ft time and suspension setup?
Your not going to run a very good time if you are just sitting there spinning so back off the power some at the line then start spraying at the 60ft mark or something.
Old Aug 24, 2009 | 04:33 PM
00ChevyScott's Avatar
Wearin' da big hat
what psi are you running in the slicks?
Old Aug 24, 2009 | 05:02 PM
60ft is 1.8xx spinning and a few 1.9s and 2.0 psi is 12-15 tried a few.
i can spray about 10 feet out and it will hook fine its just the hard hit at first that gets them spinning. I was just trying to see if there is a way to help me hook b4 traction bars. suspension is just beltech 4in drop springs.
Old Aug 24, 2009 | 05:05 PM
Toomnymods's Avatar
pull the front sway bar and install traction bars.. that helps me beable to spray immediatly
Old Aug 24, 2009 | 05:07 PM
Wearin' da big hat
I pull 1.8 60fts all the time on 20 psi in my M/T ET streets, 28x10.5 16, no spin at all unless I don't heat them up properly.
Old Aug 24, 2009 | 05:20 PM
are you spraying any?
Old Aug 24, 2009 | 05:25 PM
Wearin' da big hat
No but I have a 3800 converter and launch it WOT off the line. Have you tried doing a longer/better burnout? Or trying launching it at different RPMs off the line?
