TIME SLIP DATABASE
Front brakes?
Old Oct 17, 2010 | 11:09 PM
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by DV2000NJ
Dude, these are your ******* BRAKES that you're talking about. Do you really want to cheap out on the only thing keeping your truck from being a twisted heap of steel?
Either spend the money, or deal with the weight.
^ this is probably the route I am taking but I am really curious.
Old Oct 18, 2010 | 12:02 AM
2005 Silverado's Avatar
SPAM HUNTER
Most people have to run a line lock so that when you apply it it prevents fluid pressure from seeing the rear brakes. Let off the brake, apply the line lock, fronts work rears dont.
Has to do with some ABS systems liking the conventional way.
Old Oct 18, 2010 | 05:41 AM
custm2500's Avatar
Ph.D. in HUBRIS
I installed mime traditionally with no ABS problems but I can understand possibly having ABS issues and tricking the truck.
Old Oct 18, 2010 | 06:25 AM
sprayedenali's Avatar
how his is set up has nothing to do with ABS, its just how we installed it and it works just perfectly!
Old Oct 18, 2010 | 08:07 AM
mhotrodscooter's Avatar
This would be like using your E brake to stop @ 100mph. You'd probably lock the back wheels up & bang the wall a couple of times.
Old Oct 18, 2010 | 11:14 AM
custm2500's Avatar
Ph.D. in HUBRIS
The service brakes have more stooping force and are able to be controlled with much more accuracy then the e brake that is basically on and off.
Old Oct 18, 2010 | 11:41 AM
I know a street bike doesn't stop very good, by just applying back brakes. I think the weight transfer would have locking the brakes up.
chevrolet all the way's Avatar
Originally Posted by custm2500
Why would you line lock allow you to only have front brakes? The line lock should be on the front brakes and when engaged it will allow the fronts to work normal but they won't release because a line lock is a one way valve basically.
This is also why you put a line lock on a momentary switch not a toggle.
its on a toggle so something stupid doesn't happen. i would hate for it to cut off during a burnout. i just have to pay attention.
i have it set up so that the fluid is locked away from the rears so that i have front brakes that i can use so i can roll out of the burnout and apply the needed pressure not just on or off.
you realize you are saying all of these fast cars with no front brakes...
these are 9 second or lower cars that weight a hell of a lot less than your truck. i would bet most rear brake only cars weigh less than 3500lbs...
Old Oct 18, 2010 | 04:33 PM
custm2500's Avatar
Ph.D. in HUBRIS
I called the track go to and they said they wouldn't say anything. He said I should be just fine but if I push 120-130 mph it would be about time to add shoot just for back up.
The only down side he said is if I run in a class that crossing the stage lights is disqualification. So that is the only reason many door slammers run front brakes so they have more control to not pass the stage area. I don't plan to run in a class at least for now so that isn't a big deal.
I might search for a light weight caliper and work some weight out of the rotors.
Old Oct 18, 2010 | 05:26 PM
StreetFreak's Avatar
This seems to be a fine example of Darwinism in effect.
