TIME SLIP DATABASE
Fontana drag strip
Old Apr 7, 2019 | 07:45 PM
Chevyss909's Avatar
Default Fontana drag strip
Need to get a lil better, any pointers on getting the 60ft down. I have caltracs and launch at 2500k. Stall is a 3200 4l60e. Mine is the 12.5
Old Apr 8, 2019 | 05:24 AM
madmann26's Avatar
What's your tire pressure at? Have you tried leaving at 3k?
Old Apr 11, 2019 | 05:12 PM
Chevyss909's Avatar
18lbs highest I have left is about 2k anything higher and I lose traction
Old Apr 12, 2019 | 07:26 AM
pittman's Avatar
What tires do you have ?
Gears ?
Old Apr 12, 2019 | 09:54 PM
Chevyss909's Avatar
Gears ?
mickey Thompson et street 18x10
4.10
Old Apr 13, 2019 | 06:25 AM
pittman's Avatar
Very hard to sixty good on 18 inch tires....but 18psi is a good start. I always had better luck launching just over idle, down around 1100rpm.
I run 18 inch MT on the street and tried them at the Bowling Green track under good conditions. 1.8 was the best i could do, which sux
Old Apr 14, 2019 | 06:44 AM
Chevyss909's Avatar
maybe it’s time for a 15x10
Old Apr 14, 2019 | 08:52 AM
pittman's Avatar
That will do the trick....and maybe get a little higher TC, 3600 is still good for the street.
Old Apr 14, 2019 | 08:43 PM
Chevyss909's Avatar
thanks for ur help
Old May 9, 2019 | 11:33 PM
SleeperGMC's Avatar
I have always had better luck letting the converter flash from almost idle, than stalling it up and then flooring it.
it shocks the tires a little harder and if your caltracs are setup properly it should work better.
SLOXCAB
Feb 28, 2010 09:42 PM
speedy02
Nov 1, 2005 12:15 AM
CHarris
19
Apr 10, 2005 12:45 PM
Chingon
Jul 30, 2004 12:26 PM
