First time to the track with mods
Hey guys I went to the track tonight best run was 16.5 @ 83. My truck is a RCSB 2000 Silverado 4.8l 4X4 Z71. Mods are:
Spector Intake
Flowmaster exhaust
00 ls1 cam w/springs
Hp tuners (still learning to tune) 20-21 degrees of timing up to 6000 shift
3.73 gears, stock trans, stock converter.
I was spinning on the launch a little bit with a 60' of 2.6 consistently, but my question is does that time sound close or ballpark to were you think it should be? Any input if this is wrong would be greatly appreciated
Thanks guys
Spector Intake
Flowmaster exhaust
Thanks guys
Look up the da of your track and post it on here. Also, I'm sure a few guys would help with your tune if you posted it up as well. Just as long as you come back with more track results
IMO that sounds a little lazy, but not out of the question. Did you see any Knock Retard during the run?
IMO that sounds a little lazy, but not out of the question. Did you see any Knock Retard during the run?Trust me i hope to keep posting results. this truck will have a PT6262 on it at some point i just need to learn the mistakes now so i don't blow my motor to high heaven down the road.
temperature = 68.0 deg f
relative humidity = 49 %
uncorrected barometer* = 29.95 Hg
corrected barometer* = 30.03 Hg
density altitude = 872.40 ft
ARC
57
Feb 21, 2022 10:54 AM
