TIME SLIP DATABASE
First time with the new setup
Old Jul 21, 2012 | 02:49 PM
shanesss's Avatar
Default First time with the new setup
well i went to Bandimere the other day and went a 12.1 @113 with a shitty 1.87 60ft. I left the line spinning all 4.The DA was just shy of 9,000 that day. This was on 5-6 lbs. Iam very happy with it for now. We are not done with the tunning, Zippy is thinking low, low 11s or high 10s with more boost. Big thanks to him!!!
Mods are in sig.
Old Jul 22, 2012 | 04:20 AM
slowec's Avatar
Looks like good times for all you had working against you. Stickier tires in the plans?
Old Jul 22, 2012 | 01:25 PM
oakley6575's Avatar
Did this truck ever make it to a dyno?
Old Jul 22, 2012 | 03:05 PM
sureshot's Avatar
Congrats man! Excellent times considering everything. How much boost do you want to run eventually?
Old Jul 22, 2012 | 04:31 PM
shanesss's Avatar
We dont have a dyno out here with this wheel base. its on a strret tune with hp tuners. I want to end up around 15 lbs. Im fairly confident that i can get at least a low 11 with that.
I will be going to truck fest here in a few weeks, im gonna try to pick up a smaller pulley and see what it will do on 10 lbs.
Old Jul 22, 2012 | 04:43 PM
sureshot's Avatar
What size pulley are you running now? 6 or 8 rib?
Old Jul 23, 2012 | 07:10 AM
pittman's Avatar
That thing may just see a ten second slip.
Old Jul 24, 2012 | 10:17 AM
shanesss's Avatar
It has a 3.7 6 rib. I will be switching to 8 rib at some point soon
Old Aug 8, 2012 | 10:23 PM
shanesss's Avatar
well i went to bandimere for truck fest the other weekend and ran the truck again. I was hopeing to get a smaller pulley to see if i can get closer to 10 lbs but that did not happen. i ran it again with with the 3.7 that gets me 5-6 lbs.The D/A was almost 9400 that day and the elevation is still 5800ft lol .....It ran 11.8 @114 with a 1.71 60".
I am very happy with the results but I did order the 3.4 pulley and will be keeping you posted for new times
Old Aug 9, 2012 | 05:04 AM
dragpac's Avatar
I can't imagine 9400 ft da,that's a fast truck.good luck!
