TIME SLIP DATABASE
first time drag truck
Old Aug 21, 2009 | 03:16 PM
wolfe's Avatar
Registered User
Default first time drag truck
ok i'm new at this forum stuff so bare with me. i just posted the same thread in the wrong spot. i have a 86 silverado that i want to drag. this will be my first time building anything like this. i think i want to go with a 383, my question is:
with a heavy truck what power band should i try to stay in. i know i can get my bottom end with low gears like 4.10s so i'm thinking 2000 to 3500 with a 2500 stall, but i'm not sure if thats the best way to go. i want to get the most possible hp to the ground out of this small block.
also i might want to blow it, this will oviously change what comp. ratio, heads, pistions...will this effect the power band i'm in? any helpfull tips would be great.
Old Aug 21, 2009 | 03:28 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
For a all out drag truck bump up that stall to 4000rpm on an NA engine. Welcome to the forum, there is a lot of written info here, your best bet is to look around and find the trucks that are doing well and are somewhat like your goals. Good luck!
Old Aug 21, 2009 | 04:37 PM
pittman's Avatar
Welcome,
I don't think you will want 410 gears if you blow it. I'm no expert on that but I know most of the vette guys go with much less gears when going FI. If you stay NA, the 410 should work well. I am hitting redline right at the traps.
Pitt
Old Aug 22, 2009 | 07:32 AM
litreddevil's Avatar
Banned
Originally Posted by pittman
Welcome,
Pitt
hey but you have a moster under the hood.
bad to the topic you need to make up your mind and figure if you are going n/a are blown that makes a big difference in the set up.really for the money you could put a ls base motor and go faster are just as fast and still keep the everyday use.
Old Aug 22, 2009 | 09:42 AM
TXsilverado's Avatar
yep...and if its a true drag truck, with zero street use, throw in a 4500+ converter, huge cam and a t-brake with a power glide.
Old Aug 22, 2009 | 10:34 AM
wolfe's Avatar
Registered User
ok this is all great info. i'm pretty sure i want to blow it. so once again, when i buy all my components should i try to build for top end, and get my bottom end with my gear ratio?
and if a 383 is a bad choice for my application, please suggest another small block. i have a small block i want to make good use of.
Old Aug 22, 2009 | 11:20 AM
Snacktime's Avatar
Made in South Korea
6.0L to start would be you can always go bigger down the road.
i would throw in a 454
Old Aug 22, 2009 | 04:01 PM
la cheater's Avatar
welcome to pt net,what #s are you looking to get, the 11.5 sec zone is great there is alot of competition.
Old Aug 22, 2009 | 04:37 PM
cant call a 11.5 second truck a drag truck IMO. doesnt even need a roll cage at 11.5
