TIME SLIP DATABASE
first LS lifted truck in the 11's
Old Dec 2, 2014 | 05:05 PM
  #21
George C....'s Avatar
Formerly ScreamingL
Originally Posted by sharpshooter
ScreamingL
D1SC
Stock 317's
Vinci trucker cam 216/224 .551 .551 lsa 115
It's the exact same build as my signature. The only difference is it has a big red bypass and I run a tial.
My track time in my sig. was 3 years ago on lower boost and lower shift points. Now I'm going to run mine again. Lol
these setups ever been dyno'd?
what exhaust mods?
Old Dec 2, 2014 | 05:06 PM
  #22
Formerly ScreamingL
Vortec350ss - We run 4.11 gears with 32" tall tires. It's crossing the line at 5200 in third,shift points are at 6000. Like your saying running a stall will help the 60' and I think it will flare higher in 3rd closer to upper 5k's at the finish line. We don't lock the converters at all with procharger's. Also your right a different wheel and tire would help but we run them how we drive them on the street. (New tires and wheels weigh the same as the old combo)
why such low rpm shifts?
Old Dec 2, 2014 | 05:09 PM
  #23
GREENSIERRA's Avatar
my tires weight 84lbs each plus rims. lol
Old Dec 2, 2014 | 06:10 PM
  #24
ILWALKU's Avatar
Registered User
Small pulley .. running a 3.4 if we shifted at 6700 it'd be like 19psi then kaboom!.
this puts me into a higher HP range during the 1/4 safer.
Old Dec 2, 2014 | 06:12 PM
  #25
ILWALKU's Avatar
Registered User
Originally Posted by thewrx
Nice time but whats up with the lifted trucks streching the sidewalls like the hellaflush import guys? I saw a ram 2500 diesel with the same big lip, stretched low pro street tire on a massive lift.
Swag. Lol I Like some of the stretched look. As long as it's on 12" rim 14's are just to wide ..
Old Dec 2, 2014 | 06:19 PM
  #26
Formerly ScreamingL
3.2 pulley here and 6700 shifts but no where near that psi
stock motor will take 19psi all day long in right hands tho
Old Dec 2, 2014 | 06:32 PM
  #27
sharpshooter's Avatar
P1SC doesn't equal D1SC
Old Dec 2, 2014 | 06:36 PM
  #28
Formerly ScreamingL
correct but only seeing 11-12 psi but at same time using bigger heads and 4" exhaust so restriction is gone
what is the power these two combos are making?
and isnt there only a 200 cfm difference between a d1sc and p1sc
Old Dec 2, 2014 | 07:00 PM
  #29
They've never been on a dyno.
Old Dec 2, 2014 | 07:10 PM
  #30
Formerly ScreamingL
whats weights of these trucks?
how much timing?
