TIME SLIP DATABASE
Finally... took my s-box to the track
Old Apr 26, 2023 | 05:14 AM
  #21
10 Second Club
Originally Posted by RDF1
Where did you weigh your truck? 4800 sounds kinda heavy for a RC.
My extended cab only weighed 4700
Track scales said it was 4635lbs, then add me into the equations. I am 175-180ish. 1/2 tank of fuel on board as well.
Old Apr 26, 2023 | 05:15 AM
  #22
10 Second Club
Not going to lie, I'd be disappointed. I ran 13.88 with a stock 5.3 in an ecsb back in the early 2000's. No clue what the specs of your pet name cam is though...
It is disappointing. What was all done to your old truck?
Old Apr 26, 2023 | 10:47 AM
  #23
TXsilverado's Avatar
bone stock L33 5.3 with all of the supporting bolt on mods. CAI, ported throttle body, 4.10 gears, headers, 3200 stall, tune, e-fans, 160 thermo, underdrive pulley, slicks and pulled weight by removing the spare, pass seat and back seat. to be fair 'm still the only one that I know of to run a 13 in a ecsb with an untouched 5.3. Smart people immediately install a cam LOL. The same combo with a bone stock 5.7 ls1 went 13.22. heads and cam later it was running 12.19 N/A.
Old Apr 26, 2023 | 10:49 AM
  #24
I remember the good ole days!!
I think i saw you at the Evadale track years ago
Its a 214/222 .550"/.550" 108LSA
That must have been more than a decade ago LOL. What are the goals for the truck? Beau tried a 108 LSA cam on a truck manifold and never had much luck. The 108 LSA stuff is better suited for single plane intakes IMO.
Old Apr 26, 2023 | 11:07 AM
  #25
RDF1's Avatar
DuNnO
5 Year Member
Oh it was way more than 10 years ago. i think it was 2008ish?
Kid dropped off a truck this morning with a 4.8 and trucknorris 212/22X, .552/.552, 107 LSA
So far i dont like it haha. Stock converter and 3.23s with 31" tire. It has that cool kid idle sound but doesnt seem to have much powers.
Old Apr 26, 2023 | 01:59 PM
  #26
10 Second Club
I read/saw all the hype about these cams and the head swap, tried it for myself. To me, it's garbage. The goal is to keep trying different heads and cams. I have a "final" set up in mind and already own most of the parts required. At one point I was thinking turbo, but may just abandon that and put a turbo on my 2500HD instead. Mild setup with an appropriate sized turbo would be a good workhorse in my mind.
Old Apr 26, 2023 | 02:00 PM
  #27
10 Second Club
That's a good running combination.
Old Apr 26, 2023 | 06:13 PM
  #28
10 Second Club
A friend offered me a set of 245/50 16 Nitto drags, thoughts? I think without adjusting anything in the tune it will just short shift. They're WAY shorter than what I've got currently. It would help the gearing, but will it be effective?
Old Apr 26, 2023 | 06:21 PM
  #29
RDF1's Avatar
DuNnO
5 Year Member
There is one way to find out!
If it hooks it should help it a little atleast.
Old Apr 26, 2023 | 06:42 PM
  #30
10 Second Club
I did the math, and the tire height difference would be pretty much the equivalent of swapping my 4.11s for 5.13 gears. It would have the launch ratio similar to that of a truck with a 4L60E (3.06 1st gear) 3.06 * 4.11 = 12.5766 vs. 2.48 * 5.13 = 12.7224
I was hoping to at least find some used 255/50s, but no luck thus far. The next closest thing is another friend with a set of useable 275/45 16s, but they're more of a stiff sidewall road course tire than a drag radial. (Most likely wouldn't work for what I'm trying to do)
