TIME SLIP DATABASE
Drag radial time
Old Feb 24, 2007 | 09:19 PM
97BadazzSil's Avatar
Default Drag radial time
How much of a gain can be expected with a set of drag radials?
Old Feb 24, 2007 | 09:20 PM
TXsilverado's Avatar
how bad is your traction? whats your setup? too many variables really
Old Feb 24, 2007 | 09:25 PM
Traction is not to bad but could be better, depends on the track prep, but most of the time I get a 5ft or so slight spin.
Old Feb 24, 2007 | 09:32 PM
v8
17,16,15,14,13,12,11 Drvr
not much then, maybe .05 in the big end.
Old Feb 24, 2007 | 09:37 PM
white1's Avatar
Depends what youre going from. From a 31" all terrain to a 26" DR. I went .5 better. From a 28" slick to a DR Ill have to let you know.
A lot depends on what kind of traction issues you have now, what the overal diameter change will be, and what weight changes will be. Going from a 75/55 20 to a 255/50 16 (dr) will give you a pretty good gain. If you have the stock 16's you wont gain as much
Old Feb 25, 2007 | 10:53 AM
Pretty much same size tire only difference is 275/60/15 is what is on there now and the drag radial is 275/50/15. I was just looking for maybe a .1 or so every little bit helps.
Old Feb 25, 2007 | 11:25 AM
Leroy_454's Avatar
It would probably help you out quite a bit. The Mickey Thompson radials would probably be your best bet. I am about to try some in that size on my 90 SS. My only mod was removed cat and a magnaflow muffler, and I wouldn't get any traction. Going to try them on the stock steel wheels with factory G80 limited slip. If they don't work out, I will get 10" rims and try to fit a wider tire.
Old Feb 25, 2007 | 11:50 AM
white1's Avatar
You should get that .1 you're wanting. Its a slightly smaller tire, and will hook a little better. If you can get your 60' down a little you'll defiantly get your .1 in the 1/4. My bet is you would benefit more from a little suspension work though
Old Feb 25, 2007 | 05:58 PM
speedy02's Avatar
I love running the M/T DR's. The best 60' i have pulled with them on the truck is 1.610 and get consistent 1.6's on the spray.
Old Feb 28, 2007 | 09:48 PM
kingots2004's Avatar
i run the 28 inch m and h racemaster drag radials on the 16 inch rim and they hook like gangbusters on the street
